My 1980 Hunter 30 rennovation
Jun 25, 2013
143
Hunter 30 Montreal
Hi,
Here are few more pictures of my wood wheel project.
Here is the hub. A machine shop did it for me for 80$ CAD. It is the sama as my actual stainless steel wheel.
I used a masking tape to find the lenght of the diameter (circonference?).
I taped again my hub and then I mark the 6 makrs I need before drilling.
I punched them.
Press drill to drill my 6 holes to help me for welding by maintaining the 3/8 inches SS rod in place.
Measuring the lenght of each rod
I used a Zip Cut disc on a small grinder.
Smoothing the end of each rod.
Here is what should it looks like!
To be continued...
Jun 25, 2013
143
Hunter 30 Montreal
I continue,
I'm not a welder, but I really like to use my old welding machine.
On the wood lathe, I make small mahogany pins.
I make them tapered.
I glued them with epoxy. They don't touch to the SS rod, I want the wood can keep moving with humidity changes.
First coat of Epifanes clear varnish.
I don't know if I will follow my first plan: painting the stainless steel parts in flat black color like my stainless steel dinghy davits (see pictures on previous pages of this post).
To be continued!
pateco
Aug 12, 2014
2,207
That wheel looks awesome!! Great work.
PS. In my opinion, l would stick with the stainless spokes and hub instead of painted black. Looks too nice to paint, and you could always paint it later.
Jun 22, 2004
47
Hunter 35 St Augustine
Wow......I am very impressed! The entire project looks awesome.....the before and after are great(which I always forget to do...take the pictures). To take on things that are unknown and hit them out of the park must be a great feeling!
Good job....
Oct 24, 2010
2,405
Hunter 30 Everett, WA
Your work is outstanding but the effort you wint through to share it is also.
This is great!
Ken
Jun 25, 2013
143
Hunter 30 Montreal
Hi,
Here are few pictures of my full enclisure dodger and bimini projetc. I bought the Sailrite "make your own dodger" Dvd. Iare did the bimini using the same techniques. I am now working on the panels to make a full enclosure.
Sailrite videos are great! However, I bought all the material, fabrics and so here due to custom fees and shipping costs.
143
Hunter 30 Montreal
Hi pateco,
All the pictures I took for the dodger are here:
http://smg.photobucket.com/user/Low_S/library/Fuligule/dodger?sort=3&page=1
And pictures for bimini here:
http://smg.photobucket.com/user/Low_S/library/Fuligule/Bimini?sort=3&page=1
Pictures for the full enclosure will be in other folder (not done yet). I presently working on the panels.
I will continue to put more pict by the time I continue the project. However, I think I don't have the knoledge in english to express all I could.
I hope you will find the project interesting!
To be continued...
Jun 25, 2013
143
Hunter 30 Montreal
More pictures...
With scrap pieces, I made a cover panel for the front window to protect it from UV's when we are not onboard.
On each side of the dodger, I made a small pcket, but I found that there was lost space. So I decided to add more and bigger pockets!
BEFORE:
NOW:
With general tension on fabric, the top panel of the dodger is now well flat. Iy is the same with the bimini top, but I've still have waves in the fabric in the center (between the dodger and bimini). No problem, water is coming down.
Pockets make all the space clean.
Here is a front vue.
I am very happy of the result. Now I began to work on the side panels for the full enclosure.
Jun 25, 2013
143
Hunter 30 Montreal
This time, I try something different. I leaved zippers on the patterning material:
Oct 24, 2010
2,405
Great work! I'm curious, did you take the backstay down or zipper it in the bimini?
Ken
Jun 25, 2013
143
Hunter 30 Montreal
Ken
I Ken,
For the moment, I take the backstay down, but it's just to allow me using the bimini this summer and finish the full enclosure with the side panels. I will had zippers at the end of the season and for sure, add more snaps and velcro.
