I apologize up front for this lengthy post but it was needed to clarify my question. These are exchanges with the USCG that I have had concerning my oday so please bear with me.
"I have a question about lighting on my sailboat. The boat is just short of 7 meters in length. It now has the bow mounted bi-color nav lights and an all around masthead light. The masthead light may be for navigation or it may be an anchor light I assume. The boat does not have a stern light and did not come from the manufacturer with a stern light installed. My question is this.
Can I use my bow mounted nav lights and the all around masthead light at night under sail? I believe that if I am under power at night I turn off the masthead all around light and use my bow mounted nav lights and stern light (which it does not have right now). I am often under sail and power at night so I do not want anything that would illuminate the sails since I would be blinded at that point for night vision. This would make a mast mounted "steaming" light a bad idea. I think what I can do is just add a stern light and turn off the masthead all around light for powering at night(with the bow mounted nav lights on of course). This brings up another question however. If I mount a stern light in the center of the transom it will be partially blocked by the rudder post. Is it legal to mount a flush mounted stern light off center to avoid having a portion of the light blocked by the rudder post?
I would mount it on a staff under the boom but it would get in the way of the tiller. Thanks so much for any advice you can give me."
From the USCG:
As you indicated, sailing vessels should have a sidelight and stern light (per Rule 25(a)) these lights may be combined in one lantern at the top of the mast (per Rule 25(b)). If under 7 meters they shall, if practicable, exhibit these lights. If impractical, then a white light.
Since you often operate your vessel under power at night, you are really a power-driven vessel and therefore required to display sidelights and a sternlight (per Rule 23(a) and (c)).
Rule 21 (c) says: Sternlight means a white light placed as nearly as practicable at the stern showing an unbroken light over an arc of the horizon of 135° and so fixed as to show the light 67.5° from right aft on each side of the vessel.
Annex I covers the rules regarding light placement and doesn't specify anything more specific for the placement of a sternlight on a vessel of your size. That being said, the option you provided (mount a flush mounted stern light off center) would sufficiently meet the requirement.
We hope this answers your inquiry and we exhort you to always navigate safely,
U.S. Coast Guard
Office of Navigation Systems
Washington, DC 20593-7851
I am still a bit confused. I obviously need to mount a stern light which I have done but I do not want to mount a "masthead" or "steaming" light because it will illuminate the sail and I will not be able to see at night. Can I use the all around anchor light which is visible for 2 nm , my bow nav lights and the stern light without adding the steaming light?
From the USCG:
U.S. Coast Guard
