I have found on all 3 sailboats I have owned, that there is always more space available in the hull of the boat than is accessable.
it seems that the bigger the boat, the more space can be found...
on our Cal 34-3, there was a panel screwed to the wall behind the head, covering a small hole for the access to the hose and clamps to the deck pumpout fitting and vent.
the usable space behind this panel is 30"Long, 20"High and 15"Deep....
also there were swinging doors below the sink/vanity counter... this left 36-40 inches of room under the vanity counter towards the outside of the boat that could not be seen into or even easily reached in any way... the space had the shelves already installed, but just not accessable.....
as shown in the photos, you can see my remedy to the problems... I cut the access hole behind the head bigger built a door that would allow easy access and also installed a shelf.
under the sink/vanity counter I removed 1 door, and cut the opening larger, then framed it with mahogany... we now have a lot of storage in the head area....
and i also added a bathroom fan...
then I opened up some room under the nav station, behind the drawers.... a space 12X14 and 24 inches tall... and I am in the process of building a door for the cutout which is on the settee side of the nav station.
(also, I have never understood why there was no seat back between the galley and the dinette.... when setting there it becomes uncomfortable after awhile, and when the dinette is made down into a bed, the pillows keep sliding out, so i filled it in.
my plan is to install a swing up counter top for a bit more counter space when cooking and the dinette table is not available)...
in this boat there is two sets of sliding drawers, 1 set in the v-berth and 1 set under the nav station... i have found that there was a lot of hidden space under the bottom drawer in both of them...in this space there is mounted to the liner, 12v power distribution/jct blocks (easy access to the lighting and other 12v circuits).
so I built a removable false floor in both of them so that we could use the space for storage.... we just need to slide the drawer all the way out to access it.... but its still more convenient than going to one of the bins in the lazerette.
I will confess that we dont have the boat so full that we have all the space filled up, or even half of the space filled up, but if ever we need the space we now have it available.
all the other space is either under the quarter berth, under the v-berth, or under the cockpit/lazerette which is a lot of room but they are all a PIA to get at (except for whats on top in the lazerette)...
I plan to cut the v/berth cushions in half so I can get to the three different compartments without needing to shift all the bedding and remove an entire cushion.
the v-berth in the Cal 34-3 is almost 8' wide at the aft end, 30" wide at the fore end and 6'7" long... and the cushions are 5" thick, High density foam, made in two pieces (divided lengthwise)... very heavy and bulky to try and access the storage compartments below them and it would be so much easier lifting a quarter of a cushion rather than trying to lift a full half.
