Disagree about setting up mast pre-bend / pre-bow on this boat - impossible to do without forward lower shrouds, check stays, etc. The drawing shows that this mast can be bowed only by backstay tension (working against a tight forestay).
Special consideration: setting up mast bend via backstay tension will be inhibited by the tension in the single aft lower stays. To set this up with max. mast bend, do this in order: -
1. LOOSEN the aft lower stay,
2. apply your desired backstay tension / mast bend, then ...
3. 'run up' the tension on the aft lowers until strong 'hand-tight'.
Note: when finished sailing for the day, the mast should be brought back to 'straight-up'.
Especially if this is a Johnson (White Bear Lake, MN) built boat, Id expect that the side stays are rapid hand adjustment turnbuckles - a BIG hex-nut and a spring-type nut restrainer that 'rides' on TWO 'indexed' chain plate 'extensions'. This was the typical Johnson rigging hardware - for about 90 years until they stopped (?) making 'scows' and other sport boats.
Does this mast fit into a deep 'socket' on the coach roof, or alternately a wedge shaped metal 'bar' with the apex of the wedge pointing 'up'?
Are there thick 'wood wedges' placed along the side of the mast at its base on the coach roof?
If yes, the cap shrouds are just run up 'hard' hand tight after the maximum backstay tension is applied to bend the mast ... in accordance to the day's conditions.
Your location is on the periphery of 'ILYA scow country'. FWIW and If possible, Id recommend for you to seek out a big scow owner (M20, I20, C or D-scow, E-scow or larger) locally to help you set up and show you how to bend this mast and to set the tension of the rigging ... especially if there is a 'deep 'socket' for the base / butt of the mast to 'fit in'.
Again, Id recommend that you 'measure' the mainsail on flat ground to determine if or how much the luff is 'forward curved'.
Also, if the mast can easily be bent ...if 'easy' and the mast groove is sufficiently large, Id recommend that you consider to attempt to remove the slugs and see if the mainsail luff 'boltrope' (a three strand dacron rope inside a sleeve tape) can fit inside the mast 'groove'. Reason: if you 'can' significantly bow/bend this mast the boltrope IN the groove will affect a smooth luff shape. With slugs and a bended mast, the space/distance between the mast and the sail will be 'variable' and you wont get 'prime' sail 'shape'.
More: for a 'fast' boat like yours, you generally want the maximum draft to be 'well forward' and the luff leading edge shape 'well rounded'; therefore, HEAVY halyard tension for other than light wind sailing.
