Almost Ready
961
Macgregor & Island Packet VENTURE 25 & IP-38 NORTH EAST, MD
It's been afew weeks, hows the project going?? Don't leave us all hanging.
Its Going
Hey Cuscus:
Thanks CusCus
I took a week off and visited my Father. So... not much.... I have moved the pads and painted under those. And I completed fairing the lead bulb on the keel.... and three coats of epoxy barrier coat on the hull and keel and one coat of a bright red enamel on the hull and keel. I've been a little hampered by the cold. For instance it was well after 2:00PM today before the temp got above 60F. Cant do epoxy at those temps and enamel will "orange peel" when it is cold like that. I am close though. As soon as I get some time off work AND it is above 65F, I can get the second coat of paint on and start thinking about putting the keel back in place.
I'll post pics.
961
Yeah, this cooler than usual spring is really putting the boatyards around here behind. Too cold for bottom painting & glass work. I haven't seen so many boats still on the hard this late before.
Got some new photos...
Well it stopped raining around 4:00 and I was able to get a few things done....
First, I made some gaskets out of "Goop" (see first photo). I also have some butyl tape that I'll use as well.
And I fitted out a SS pivot bolt. While I was checking the fit, I was cleaning up some "mud" that was in the pivot hole and noticed that the mud had wood fiber in it...:naughty: So I got worried and cut an access hole to the pivot pin. Dang..... to say the repair job was halfa$$ is an insult to all the Gomer Piles of the world.... (see pic #2)... There was no way to get a good dry seal around that.... so... I had to remove it entirely. See the next two pics. I'm going to make a backing plate out of Trex tomorrow.
More pics to come....
r
