Attached is what I referred to. It appears not to be part of the fuel system, so I’m ruling it out as a source. There seems to be some leakage from the filter itself, though it is on tighter than before I changed it. When I removed the secondary filter, there was a thicker gauge o-ring packing than what was provided with the new filter, which seems odd. I assume a thicker o ring may have been used to better seal the filter housing.
Is there any reason NOT to run the engine at 3200 for 10 hours to try reset the rings? Fuel and gear oil did not leak prior to running at open throttle, and I’m wondering if it may have somehow caused the leaks? I thought the fuel filter may have been clogged and changed it for that reason (last filter change of both primary and secondary was 300 hours prior), but the leak persists.
