What is this mystery line?
capta
Jun 4, 2009
5,090
Personally, I do not favor the use of harnesses and tethers unless one must go out a bowsprit in heavy weather, or work forward when the deck is awash. And only then if I have someone on the end of the tether, tailing the line.
The idea of trusting my life to a line and some fittings has never set well with me. The old adage, "one hand for me and one for the boat, and if more hands are needed, call another crew member to help." has always worked well for me. I'm certainly not too proud to slither up the deck on my belly to go forward, if the need arises.
Of all the ends a sailor could possibly experience at sea aboard a sailboat, being bashed against the hull and broken up into bits and pieces inside, is the least desirable to me.
capta
Jun 4, 2009
5,090
I suspect the line will be strong enough. You need a solid clip to attach it to the dog's harness. The Kong Clip may be over engineered for this purpose. I'd use one of the new-styled body harnesses.
Our Aussie has not yet been on the boat. She is only 37 lbs but filled with energy and a dislike for deep water. A 6-inch-deep mud puddle, preferably one that turns her white fur black/brown, has been her go-to desire.
Somehow, ""a dislike for deep water" does not seem out of place for a dog bred for farm and ranch work. lol
Some would say, from her point of view, she is smarter than you, JS. I suspect sometimes she is.
Jun 14, 2010
2,483
It is a really bad idea that was once employed as a tether for a harness. The bad idea was there was no way to easily release the tether from the harness if you were being dragged along side the boat. Also, the carabiner could snag on the pad eye and inadvertently open rendering the tether useless.
Modern tethers have a quick release shackle at the harness end and a double action clip at the pad eye/jack line end.
I used to have one, never used it.
Bing bing bing! We have a winner. I still have one of those in my garage (part of what my wife calls my “hardware store” ;)). I bought it in the 1980’s as a tether line (maybe even late 70’s) from Defender (when it was in New Rochelle NY). The harness I bought at the same time was equally crude, with unpolished stamped buckles.
Aug 28, 2006
579
Bavaria 35E seattle
Ours is not liking water either. We took her to a city park pool party for dogs this past summer - she ran around the perimeter playing with the other dogs but it was a 'no-go' getting her into the pool. It's hilarious seeing about 100 dogs running, splashing, and playing in 2 adjacent pools.
4,006
Corsair F-24 MK I Deale, MD
As a rock climber (as many hours in the air as sailing, and that is a LOT of both) I have a completely different view of jacklines.
  • Climbers rely on rigging for life every day. I understand it, I trust it, and if it is not 100% trustworthy, I fix it so that it is. There should be zero questions about the rigging. None. You should be relaxed about being caught, knowing that it is sure. I certainly do NOT want a sailor tending the line; he might be struck by the same wave ... obviously.
  • There seems to be a common practice that you use the 6' tether and stand tall. No. You use the 3' tether, or even shorter, and crouch or crawl when prudent. The 6' tether should be use only when the greater length is safe. Climbers always use the shortest practical tether, often a foot or so.
  • Some say center line. Some say near the rail. I say it is boat-specific and that the cleats are almost never the correct anchor points. I always provide dedicated jackline anchors where I want them. Also, work station tethers or anchor points are smart. Something at the mast. Something at the bow. Keep one tether on the jackline and clip short with the other.
  • You also hold on and maintain situational awareness. Very few sailors have fallen when moving. It is usually when they stop to work (and lose awareness and are not holding on).
  • If there are places that are very bad to fall (lee bow wave), position your anchors to you won't fall there. Obvious, but sailors are not climbers.
Like sailing, rigging anchors and jacklines has a learning curve, and I think most sailors, even good ones, are very near the bottom of the curve. To me, clipping, unclipping, and continuously calculating my fall trajectories, is like breathing. But I probably climb more and better than I sail.
Likes: Timm R Oday25
DArcy
Feb 11, 2017
1,787
Islander Freeport 36 Ottawa
I worked on a tall ship that had the worst harnesses I have ever seen. In fact, they were not harnesses, they were just the tether similar the one pictured in the original post, a 3-strand rope with an eye splice with the end passed through the eye splice to form a loop and a clip at the end. We were expected to wear these with the loop around our bodies any time we went into the rig. None of us ever clipped them in. Beyond the obvious hazard of having a slip knot cinch up around your waist, using any harness was not viewed as improving safety aloft. The most likely time to fall would be when climbing or descending the ratlins and you obviously can't continuously clip and unclip while doing this. While working on the yard a proper harness might help in some cases but dangling from a rope didn't appeal to anyone. The backline was a very good second line of defense while on the yard.
When the captain explained the use of the "harness" he said the insurance company required anyone going aloft to wear a harness. He knew no one used them anyway.
Mar 26, 2011
4,006
Chest harnesses of any type (used alone) have not been approved for recreational or industrial work at height for about 50 years. The change to seat harnesses was on the 70s. At the same time, shock absorption was introduced into tethers (I believe that was the invention of Simon Yates).
