Water under engine while motoring — shaft seal leak? [Photos attached]
The instructions were provided in an earlier post. The PSS has a different compression for each shaft size. I believe the 1” shaft is 3/4”compression from a static state when installed.
here is the link to the manual. They are a pretty handy tool. Try page 3. Less need to guess.
This is correct and works with a new installation. However, after the bellows has been compressed for a while it does not spring back to its original size. If you the original length, then you can adjust the measurements.
Jun 14, 2025
188
Hunter 1981 30 Chesapeake
Hi all,
I did an oil change recently and put fresh oil in my sailboat’s Yanmar 2GM20F engine. After running it for a little while, I’m noticing a small oil leak that wasn’t there before.
It seems like it’s coming from around the transmission area, but I’m not completely sure. There’s a part there with what looks like a small hole, and oil seeps out a bit when the engine is running.
Has anyone experienced this on their sailboat engine? Is that hole supposed to be there, like a vent or weep hole, or could it be a sign of a seal or gasket issue? Any advice would be much appreciated.
Thinking it may be a shift shaft seal.
Thanks!
640
Hunter 306 Pasadena MD
I didn't get through all of the posts, but one obvious thing to do if you're wondering where the water is coming from is to just put a dry sponge underneath the shaft seal, and go motor around for a while. I usually keep a sponge under my traditional stuffing box, as it's an easy way to check how much it's dripping.
Same thing for the vent hose: just put a sponge / paper towel around it, and you'll know if it's venting water.
