Wow, that looks pretty bad. Glad you're fixing it here and not contending with a failure at sea.the wood was damaged, cracked, with some amount of dry rot. Not good.
Oh yeah! Loosing the mast at sea is VERY low on my list!Wow, that looks pretty bad. Glad you're fixing it here and not contending with a failure at sea.![]()
The wood beam is in the bow structure.how the wood look where it marries to the stem?
Yes, I did look into the entire length of the bowsprit. Most of the wood looked to be in good shape. The main deterioration appeared mainly at the tip and as best we can determine likely resulted from someone probably hitting a dock with the bobstay. The direction of the wood deformation seemed to point in that direction.View attachment 217407
It always warms the heart to see beautifully executed joinery.
Looking at your renewed bowsprit and that excellent work and reading your story of discovery, I can't help but think about the waves and wakes that constantly splash up underneath that important structure and ask, how the wood look where it marries to the stem?
-Will
That beam will be mostly in tension when Sailing.
No.I'm pretty sure you meant compression
If the bow sprit was a cantilever beam your point on tension on the bottom would be valid, but this is a stayed strut. The bob stay takes the tension load from the fore stay's upward pull. The cheek stays on each side take the tension load for side-to-side forces. If you do a free-body diagram on the end of the sprit, you have four cables each at an acute angle to the sprit. By default, a cable can only carry a tension load and will buckle with compression. Therefore, the wooden sprit will have a compression load equal to the resultant of the four cables. If the inboard end of the sprit is rigidly attached to the bow of the boat, some moment load will be built into the sprit during tuning but to bottom side tension would be reduced when sailing because the baby stay is short, and the forestay is long so there is much less elongation in the baby stay.No.
When the head sail is pulling the sprit, the underside is in a tensional moment of inertia.
I looked up his wood, Iroko or African Teak. It has a huge Elastic Modulus.
Wood laminated beams do not do well in compression loads.
Jim...
We had hail last night in SJ when a storm passed over so you very well could have.Had some last night that I swear had hail in them!
