Tightening Engine Belt on Universal 5411
jviss
Feb 5, 2004
7,090
Tartan 3800 20 Westport, MA
13.7 volts. Cannot read the current, but getting a good charge always. An M-12 experienced mechanic stated that some dust throw is normal for this engine.
Nah, dust throw is due to misalignment. Take a good look - sight along the belt - is it absolutely straight? I guess not.
Apr 5, 2009
3,329
Partial correction. Belt dust is due to misalignment (unless you are trying to pull more horsepower than the belt configuration can deliver.)
In my case, I have the normal 3/8" 3-pulley system on an M25XP. This means that the belt only contacts the pulley for about 120º. Given the belt size and contact arc, about the most I can get with a perfectly aligned belt is 60-70 amps. Any more than that and I start to create a cloud of dust. My alternator is rated at 108A and I have a large LFP bank so if I do not reduce the charge output, I will burn through a belt in a few days.
jviss
Feb 5, 2004
7,090
Well, there you go! I should have said, if you have a properly designed system, belt dust is a symptom of misalignment. Get thee a serpentine belt upgrade!
Apr 5, 2009
3,329
Yep. Just need to come up with 5-boatbucks. After a new set of sails, the kitty is dry for a while.
I take exception to inferring that my belt system was not properly designed. In 1988 Universal designed it for the factory installed 51-amp internally regulated alternator and it is well designed for that application. It still works well for me as long as I stay within those parameters. Just because I am greedy power hog is no reason to besmirch the engineers at Universal. :biggrin:;)
jviss
Feb 5, 2004
7,090
I'm not besmirching the 'engineers' at Universal, I'm besmirching you! :).
  • Ha
Likes: Hayden Watson
Apr 5, 2009
3,329
Now, now. If I was pulling the full power out of my 108A alternator and smoking the belts every day that would be fair. As it is, I designed my system to limit the max output to 60A and at that power point, I get good service life out of my belts with minimal dust. Now once I get a serpentine kit, I will be upping that limit a fair bit. :beer::biggrin:
Like Clint said, A man's got to know his limitations.
Likes: jviss
jviss
Feb 5, 2004
7,090
Oh, I thought a boat buck was a grand these days. If it's still a C-note, then not so bad. But, yea, it's excessive for this kit, in my opinion.
jviss
Feb 5, 2004
7,090
I understand. It was a big leap for me to spend $500 on that serpentine belt kit, and now I'm thinking I really didn't need it, since I don't have a battery bank that can absorb the amount of current that that belt system and alternator can deliver. I ruined a pair of Trojan SC200's, at $250+ a piece, by driving them too hard. So, I have a serpentine belt system and a 125A alternator, and a bank that can only stand 25 or 30A max charging current. Duh! What was I thinking? It will be cool if I can ultimately get a LiFePo4 bank, but who knows when?
Aug 31, 2020
13
O'Day 28 Fair Haven, NY
Have a few pieces of oak or other hardwood lying around? A piece o all thread and a few nuts and washers? Make your own custom belt tensioner.
This Lochner guy seems to know some useful stuff! ;-) I just replaced my alternator belt yesterday and came here looking for a tensioning solution. This wood and threaded rod tensioner is easier for me than modifying a turnbuckle. I'll make one this week! I'm also going to change my alternator belt when it has less signs of wear in the future. The old (and cracked) belt just brought me through 2 hours of 20 knots on the nose and nasty chop. The whole engine compartment and lazarette are full of black dust. I'm grateful for its service, but sure would not have been happy if it had failed at that time.
Apr 5, 2009
3,329
> tensioning strut
Another great idea.
I think ultimately something like this is what I'll need to do because I've found that even when I do finally get the right tension on the belt and tighten down the bolt on the alt bracket and even put some lock-tite blue on it, the vibration from the engine loosens again after a few weeks.
I ran into the same problem when I went with the serpentine belt kit for my high-output alternator. The Engineer in me also struggled with the geometry of the tensioner. I ended up making a ne tensioner support out of a piece of 2"x2"x1/8" angle and this got the new Heim tensioner at 90º to the alternator pivot bolt. It is mounted to the motor mount bolts over the engine brackets.
