Tightening Engine Belt on Universal 5411
jviss
Feb 5, 2004
7,089
Tartan 3800 20 Westport, MA
13.7 volts. Cannot read the current, but getting a good charge always. An M-12 experienced mechanic stated that some dust throw is normal for this engine.
Nah, dust throw is due to misalignment. Take a good look - sight along the belt - is it absolutely straight? I guess not.
Apr 5, 2009
3,137
Partial correction. Belt dust is due to misalignment (unless you are trying to pull more horsepower than the belt configuration can deliver.)
In my case, I have the normal 3/8" 3-pulley system on an M25XP. This means that the belt only contacts the pulley for about 120º. Given the belt size and contact arc, about the most I can get with a perfectly aligned belt is 60-70 amps. Any more than that and I start to create a cloud of dust. My alternator is rated at 108A and I have a large LFP bank so if I do not reduce the charge output, I will burn through a belt in a few days.
jviss
Feb 5, 2004
7,089
Well, there you go! I should have said, if you have a properly designed system, belt dust is a symptom of misalignment. Get thee a serpentine belt upgrade!
Apr 5, 2009
3,137
Yep. Just need to come up with 5-boatbucks. After a new set of sails, the kitty is dry for a while.
I take exception to inferring that my belt system was not properly designed. In 1988 Universal designed it for the factory installed 51-amp internally regulated alternator and it is well designed for that application. It still works well for me as long as I stay within those parameters. Just because I am greedy power hog is no reason to besmirch the engineers at Universal. :biggrin:;)
jviss
Feb 5, 2004
7,089
I'm not besmirching the 'engineers' at Universal, I'm besmirching you! :).
  • Ha
Likes: Hayden Watson
Apr 5, 2009
3,137
Now, now. If I was pulling the full power out of my 108A alternator and smoking the belts every day that would be fair. As it is, I designed my system to limit the max output to 60A and at that power point, I get good service life out of my belts with minimal dust. Now once I get a serpentine kit, I will be upping that limit a fair bit. :beer::biggrin:
Like Clint said, A man's got to know his limitations.
Likes: jviss
jviss
Feb 5, 2004
7,089
Oh, I thought a boat buck was a grand these days. If it's still a C-note, then not so bad. But, yea, it's excessive for this kit, in my opinion.
jviss
Feb 5, 2004
7,089
I understand. It was a big leap for me to spend $500 on that serpentine belt kit, and now I'm thinking I really didn't need it, since I don't have a battery bank that can absorb the amount of current that that belt system and alternator can deliver. I ruined a pair of Trojan SC200's, at $250+ a piece, by driving them too hard. So, I have a serpentine belt system and a 125A alternator, and a bank that can only stand 25 or 30A max charging current. Duh! What was I thinking? It will be cool if I can ultimately get a LiFePo4 bank, but who knows when?
