Sean
I just succesfully replaced my head, and wouldn't you know it......after two trips the thru hull handle gets stripped. Fortunately it is locked in the closed position. The thru hull is the old wheel (garden hose) handle, obviously I need to replace this part, but I noticed that there is a threaded nut holding the check valve and handle to the thru hull. Does anybody know the typical size standard for a 1977 Cat 27 (assuming original thru hull)? Also checking out West's web site it looks like they have complete units, so any info on where I can find just the check valve/lever would be helpful. Thanks.Sean
