Good data. I've used it also with good results. Not sure if you know it or not but there is a screw on the side of the carb on the 9.8 that can be loosened/removed to completely drain the carb as running it dry can leave some gas still in the bottom of the bowel. It is easy/fast to do. Also the 5 and 3.5 HP Tohatsu's have a similar screw. Probably most outboards do.One more good data point for using Seafoam with Ethanol gas. At the end of February I ran my 9.8 Nissan 4 stroke outboard dry of gas (whatever I got from the closest gas station which is 10% Ethanol) and Seafoam mix and its been sitting in Lake Havasu since then. This is a fricken hot place in the summer.. been up over 120F recently and its 113F now. I have fresh gas/Seafoam with the outboard in a large plastic bucket filled with water and it started right up, no issues that I can tell. The one time I left a 4 hp four stroke without Seafoam over a summer here, the idle jet was completely closed and the float was stuck.
You guys have a great trip,
Sumner
1300 miles to The Bahamas and Back in the Mac...
Endeavour 37 Mods...
MacGregor 26-S Mods...
Mac Trips to Utah, Idaho, Canada, Florida, Bahamas
