I don't see how to engage the connector on this terminal block.
I don't think that will work in this application. The terminal block looks like it from an old Aquasignal TriColor. The block is inside the light fixture.If I were you, I'd change to the screw type terminal bloack. They come in every size and can be cut as needed from a one wire connection to ten.
