Stepping Mast Singlehanded
Dec 12, 2020
8
O’Day 24 Oneonta
Proud sailor today! Stepped the mast for the first time and single handed too! Modified a system I saw on YouTube.
How tight should the shrouds be? I saw a tension measuring device, but I don’t have one and I want to ensure I am in the ball park before I launch next week.
Feb 21, 2013
4,638
Hunter 46 Point Richmond, CA
My two cents: They should be tight enough that when you push or pull on them, they don't want to jiggle around too much. If they feel loose or floppy, you need to tighten them further. Once the cap shrouds are set, the rest of the shrouds simply follow in sequential order with none of them being tighter than the cap shrouds.
Might find these threads helpful:
Might purchase a manual here if you do not have and refer to its shroud tension procedure: I Heart O'Days - Manuals
Likes: Noodat Lady
Jul 30, 2019
216
Seaward 25 777 Fort St. James
Because, unless you are a serious racer with a keel-stepped mast to take the high tensions involved, for the rest of us with mundane, fun, recreational boats, usually with deck-stepped masts, tensions are low and not critical. Approximate works; "feel" works. Basically following sail sfbay's guidelines above works.
The reason for my strong opinion that recreational sailors should actively avoid tension gauges is that therewith lies the seemingly inevitable progression towards unnecessarily high tensions that then cause your cabin roof to droop, or strain cables, especially shrouds, to near or past their breaking point with potentially catastrophic results. I've seen it too often.
Joe
Jun 1, 2004
8,005
Every sailboat owners manual I've seen, and I've seen about 30, has a specific section on setting up the rig. None of them refer to a tension gauge. If you don't have a manual for your boat, just do a google search on the subject.
I trailer sailed my Nacra 5.2 for years, never had need for one. What is handy, though, is to use quick release shroud connectors that use pins, rather than turnbuckles for setting the tension. Way, way faster and easier.
Likes: Noodat Lady
Jul 7, 2004
8,402
Hunter 30T Cheney, KS
Even a deck stepped mast tranfers its weight to the keel via a cabin pole or load bearing bulkhead. If your cabin "droops" you've got other problems
216
I'd call it fact. Unless an owner hacked the original design. The exception being nonkeeled boats. But even they xfer to the bottom.
This is probably heading towards an impasse, but.....
With a keel-stepped mast you have a single pole with a uniform flexion. With a deck-stepped mast you have a jointed limb with a discontinuity at the tabernacle. Some boat manufacturers succeed in triangulating the supporting framework better than do others, but the system is inherently weaker.
Plus age of boats exacerbates any weakness in the triangulating members. What's the average age of boats on this forum? Mine are 21 and 47 years old.
8,402
You are right Bob. Each to his own methods. I'm confident of a very rigid xfer from mast base to keel. Other boats like old Catalinas have problems with rotting support.
Likes: Noodat Lady
Joe
Jun 1, 2004
8,005
I don't think I've heard or read anything about Catalina 27's having compression post issues. Because the posts are metal, encased in teakwood. There is also a reinforcing beam across the cabin roof. The issue you may be thinking of is the wood base plate in the bilge that the post is adjacent to. One of my boat's previous owners water proofed the pad and it has been dry for the 21 years I've had the boat. Another known issue is water finding its way into the interior bulkheads via the connected cap shroud chain plates, which can lead to bulkhead damage. There was another issue that Catalina actually designed and produced a retrofit... this regarding the 4 lower shrouds and their inadequate deck attachment... which could cause the deck area to buckle with too much strain of the guys. Knowing these and other tendencies of older boats is important so the owner can anticipate the problem and take preventative action. That's the advantage of having strong owner groups and. as in Catalina's case, continuing factory support for all the boats they've ever built and their current owners.
Some boats, not necessarily very old ones, are built to maximize interior space and the compression post has been left out of the design. Choose wisely padawan.
Likes: Justin_NSA
Nov 9, 2012
2,500
Oday 192 Lake Nockamixon
There are no rig tension specs for the average O'day in the manual. I like mine to be tight enough so that the leeward shroud doesn't go loose and move around close hauled at about 10 knots of wind.
Likes: Noodat Lady
1,925
Oday Day Sailer Wareham, MA
O'DAY 23 Original Manual/Rigging guide says this (pretty much same for all O'DAYs under 27'):
"After all stays are securely attached, take the slack out of the rigging and tighten. With the mast plumb (in a vertical position), the Headstay, Backstay, the two upper Sidestays, should he tightened 3-5 turns more than hand tight. The two lower Sidestays should be just taut, not hand tight.
CAUTION: It is very important that you do not tighten the stays too much, as this can cause damage to the hull and deck. Also, periodically you should inspect the chainplates for corrosion and the deck area around them for rotted core.
After the stays have been adjusted, take a pair of pliers (even better, use a wrench), tighten the lock nuts on the turnbuckles which will prevent the turnbuckles from unwinding. To be on the safe side, we strongly recommend that you wire and tape the turnbuckles so they will not unwind."
I think most model years of the 23-2 had "open-body" turnbuckles, so they would use cotter pins or split-rings through holes in the threaded studs to secure the turnbuckles from unwinding rather than lock-nuts used on smaller boats, but otherwise, this is how My Father and I have always "tuned" the rigging of our boats.
216
I would clarify "hand tight": I have known farmers whose "hand tight" is up in the 50 lb-ft range. To me hand tight on small boat turnbuckles means with your thumb and two fingers, no tighter. Also 3-5 full turns sounds high, I'd think that many half turns.
I'd also say "never pliers". My term for pliers is nut-f****rs. Always use a small Crescent; get a 4" one to keep in your pocket.
1,925
"Hand-Tight" means the reasonable limit on being able to turn the adjustable part of the turnbuckles by hand. But yes, will vary fro mone person to another.
Jul 30, 2019
216
Only by a factor of 10 or 20 times though. Very useful.
JRacer
Aug 9, 2011
1,333
The way I do it is to center the top of mast by measuring equal distance from the top to a point equidistant from the bow along the toe rail on each side using the main halyard. Then pull it into column with the lowers. At that point, I use Loos gauge to see what loads I have on all shrouds. From experience, I then tighten the shrouds to my recorded points. Then I sail the boat and depending on wind conditions, I tighten or loosen. If in 10kts I find that the leeward shrouds have slack, I tighten and record the Loos Guage reading (back at the dock) - it's trial and error until you have kept records, or just know from experience. What the Loos guage gives you is a relative reference point. With experience and records, I can set the rig for given conditions before I leave the dock. Don't discount the value of a Loos Guage. Agree with Noodat Lady that one can overtighten a rig and cause damage but you can do that with or without a measurement tool.
