I recently installed a 240 watt solar panel with an EPEVER XTRA2210N controller that charges 2 group 31 lead acid batteries connected in parallel. I set the controller to the default settings for lead acid and kept the default setting of 200 Ah, which is reasonable for my 2 batteries.
Now, typically when I get to the boat, the electrical panel voltmeter is pegged at 16V, though the voltage will drop quickly to 13V-ish when I put on a load. Also, I have to add distilled water to the batteries every few weeks. This makes me think the controller is charging the battery at too high a voltage.
I have not checked the battery voltage yet with a hopefully calibrated voltmeter, but will this week.
The photo shows the default settings for the controller. I should be able to change these settings in user mode when Amazon delivers the USB cable.
I have called Custom Marine Products, and they were nice, but did not give me useful advice.
Any advice on correct controller settings or anything else?
Thanks,
Paul
Thanks,
Paul
