You mentioned worrying about a shackle coming loose. Just get some seizing wire and using the hole in the pin seize it to the body of the shackle so it can't unscrew, then tape it so the sharp edge of the wire doesn't chafe on the mast and scratch the anodize. You might be able to get a plastic tie in that hole and use that as an alternate to seizing wire.
