Shore Power - SmartPlug vs. Circa 1938
Sep 15, 2009
6,244
S2 9.2a Fairhope Al
when working with AC current (120vac) it is not necessary to be concerned about wire size for a 50 ft run or less as long as the wire size is rated for the amperage coming out of the breaker...ei 30 amp = #10......20 amp = #12 ....... 15 amp = #14 ....etc....if you are concerned about wire size,go up one size.....most 30 amp shore power cords are #10 in a 50 ft length
Jun 6, 2006
6,990
I love America, thanks MS for taking the time to keep us safe.
Feb 22, 2013
25
Hunter 420 Passage Center Cockpit Marina Del Rey
What's the best recommendation if you need more than 50' of cord?
My boat is 42' but the pedestal is on the port side and boat inlet is aft starboard, so by the time I cross my wide beam, the 50' cord barely makes it and is twisted at a scary angle. In other words, I need a 52 foot shore power cord.
Jun 21, 2004
3,222
Beneteau 343 Slidell, LA
Marinco makes "extension cords" that can be added on to your present 50'cord. I recently purchased a 12foot extension, I believe that there are other lengths including 25' and perhaps 6'. The extensions have a male & female plug. There is a coupler , that must be purchased separately, that will ensure a tight weather proof seal where the extension twist locks onto the main cord. Purchased my extension from Defender; I am sure all the major chandleries have them also. As Woodster mentioned, you have to be careful with adding onto the 50 cord because the cord is only rated for a specific voltage & amperage. Check the appropriate tables to determine if the voltage drop will have any significance by adding the extension.
Sep 28, 2008
922
Canadian Sailcraft CS27 Victoria B.C.
Sorry I think I'm missing something.
You can buy the Ancor 10/3 shorepower cable in bulk and add ends to it. If you only need 52' there is no reason to add a long extension.
Marinco extensions are 12' and longer only.
CYQK
Sep 11, 2009
610
beneteau first 42 kenora
Miane
Thanks for the block suggestion that exactly what I was going to do already have a shop drawer full of blocks just thought there was something easier
You da man!!!
Feb 6, 1998
11,772
Call Smart Plug they have and can do longer lengths..
