RUNNING THROTTLE UP OUT OF GEAR
Feb 23, 2011
11
HUNTER 386 Pensacola
Hi folks. H386. How do you run up the throttle while not in gear? I seem to have no detent button on the throttle. TIA
kbgunn
Sep 19, 2017
211
2005 Hunter 33 Lake Lewisville, TX
No button in the center of the gearshift/throttle?
Right.... The single lever throttles have a button to press that allows you to increase the throttle without engaging the transmission/gearbox. On my Hunter 38 it's a black button at the base of the lever like the one shown here. Press in (maybe firmly if it hasn't been used in a while) and hold while moving the lever forward.
Likes: DayDreamer41
Jul 19, 2013
384
Pearson 31-2 Boston
The photo reminds me - I've operated a half dozen Hunter boats with these controls, and they drove me nuts because it was difficult to confirm that the shifter is in neutral as there is no positive detent for neutral. Your experience too...?
Aug 12, 2018
163
Hunter 26 Carter Lake, Colorado
Some you pull the lever outward on its shaft and then in either direction for revs without gear.
(technically it’s not a throttle on a diesel, it’s a fuel delivery rate control, I’m drawing a blank on what you’d call it though)
Feb 21, 2013
4,638
Hunter 46 Point Richmond, CA
.....H386. How do you run up the throttle while not in gear? I seem to have no detent button on the throttle...............
I also had a Hunter 386 and now 46. To run the engine rpm out of gear you to depress the black rubber button (with plunger) on the throttle handle. If you are missing one you can order a replacement rubber button and plunger from Lewmar Engine Control Mechanism | Lewmar
Likes: SVEN MARTINEZ
Tedd
Jul 25, 2013
746
TES 246 Versus near Vancouver, BC
We're having similar discussions in the electric vehicle industry. You still sometimes hear "throttle" (or even "gas pedal"!), but the most common substitute seems to be "accelerator." Somehow, that doesn't sound right for a boat, though. But "power lever" is clumsy. Any other options?
Nov 26, 2012
1,653
Hunter 34 Berkeley
You call it the throttle.
Nov 22, 2011
1,192
Ericson 26-2 San Pedro, CA
The GM Series Operation Manual, published by Yanmar, repeatedly refers to it as a "throttle." Ditto for the GM/HM Workshop Manual (not published by Yanmar but an outstanding resource).
Good enough for me.
Jan 4, 2006
6,474
That's about the closest I've seen here. The correct term from the manufacturer is called a "governor". It's purpose is to control the speed of the prop as it's coming out of the water and then digging back in when when in rough sea. When you increase the throttle, you are increasing the governor speed adjustment.
And rather than finishing up with the usual dumbass phrase of "that's a fact", this is taken from my Yanmar service manual.
in
Sep 20, 2006
2,912
Flux Capacitor Actuator
Likes: Tedd and dmax
