Runaway Yanmar
kito
Sep 13, 2012
2,011
1979 Hunter Cherubini 30 Clemmons
It is a decompression lever and my only means of shutting it down.....other than covering the air intake. I can hand crank it easily with the lever up but not when there is compression. ;)
Jul 5, 2011
775
Oday 28 Madison, CT
Interesting. The lever in my cockpit (T handle on panel) is a fuel stop. This is Universal M12, not a YSM12 however. Very surprising your lever is decompression...... Does it say it is in the owners manual or on a parts schematic?
Sep 15, 2009
6,244
S2 9.2a Fairhope Al
yanmar puts decompression levers (they keep the exhaust valve open when engaged) on there engines along with a fuel shut off lever for the injector pump universal dose not as far as i know
Jul 5, 2011
775
Oday 28 Madison, CT
Just looked at the service manual. Page 10-2 shows the set up and you are right. Stop control (standard version) was decompression. Optional was fuel shutoff control. From that I gather you could probably change it over, but it things ain't broke...............
kito
Sep 13, 2012
2,011
My manual says it has a decompression lever and a fuel stop. My Hunter 30 does not have a fuel stop pull knob, just a decompression lever. Probably because the ysm12 is a small single cylinder and designed to be manually started if needed. It's hard to get turning manually with the lever down but turns freely with the valves open.
kito
Sep 13, 2012
2,011
The ysm-8 that the OP has is basically the same as my ysm-12. Apparently O'day ran a fuel shutoff to the cockpit instead of a decompression. I would find out where the decompression lever is on the engine so you can use it next time it "runs away". Actually, I would rather have a fuel shut off in the cockpit. Only time I would need to use the decompression lever is to manually crank start it anyway.
Apex
Jun 19, 2013
1,227
C&C 30 Elk Rapids
yes, YSM-8 is almost identical to the 12, with only some minor exterior dimension changes, which made it quite a chore to properly identify sans finding the mfr plate.
I will check this w/e when on the boat as to fuel shut-off or decompression. i am 90% sure it is fuel shutoff, esp in light of the FANTASTIC information all of you have shared so far.
Hand-Cranking - Before finding the poor ground, I had plenty of opportunity to hand start, and still do just for practice at times. The bruises on the back of my hand are a reminder to make sure the handle stays engaged while cranking away. :O) But I do know the location of the decompress lever, and will file that tidbit if information as another means to try and stop that train from grenading the engine should I have a similar episode.
Now, how to keep Bear from mucking with the throttle.
MitchM
Jan 20, 2005
1,031
per Yan mar dealer Mack Boring the safest thing you can do to a diesel runaway is flatten the boat off a heel immediately. the engine is burning excess lubricating oil along wth diesel fuel. it's a particular problem with splash-lube engines on a high heel angle. on a one cylinder using the de compression lever should be 2nd choice. trying to block the air intake is not a good idea. starving the engine of air to halt combustion is theoretically possible if you have a heavy metal plate handy to slap on to the air intake, that's a lot larger than the air intake. a sponge or rag won't do it, those will just get sucked in to the air intake. then you'll have big problems trying to clean them out.
