yes, YSM-8 is almost identical to the 12, with only some minor exterior dimension changes, which made it quite a chore to properly identify sans finding the mfr plate.
I will check this w/e when on the boat as to fuel shut-off or decompression. i am 90% sure it is fuel shutoff, esp in light of the FANTASTIC information all of you have shared so far.
Hand-Cranking - Before finding the poor ground, I had plenty of opportunity to hand start, and still do just for practice at times. The bruises on the back of my hand are a reminder to make sure the handle stays engaged while cranking away. :O) But I do know the location of the decompress lever, and will file that tidbit if information as another means to try and stop that train from grenading the engine should I have a similar episode.
Now, how to keep Bear from mucking with the throttle.
