I have a 1978 33' Hunter and it has developed a leak around the bellows that is attached between where the rudder post comes thru the hull up to the top bearing. I spent a lot of time yesterday trying to get new hose clamps to stop the leak as one old one was broken but all I was able to do is get it to become a controlled drip. Right now the auto bilge pump is cycling about every hour. I also noticed that the pan under the diesel fills up to a certain height and then dumps to the bilge. Can some one explain the relationship between the shower sump, the diesel engine pan and the main bilge on this model boat. This is a new problem and luckily I had just replaced the bilge pump with a new 1200 gph pump and line all the way up to the thru-hull so it works very well. But I am not comfortable with this increase of water entering my boat, which I stay on a lot of the time. I cannot tell if the bellows if cracked, or if the surface it is mounted is corroded, or what is causing this problem. But I certainly am not comfortable leaving it alone for a very long period of time. Any help would be appreciated. Thanks.
