Lots of views...
...but no replies. Does that mean no one is going to stick their neck out? OK, I'll go first. I'm in the middle of rewiring my 26S. When I bought it the battery was dead... check with another battery showed it didn't matter- nothing electrical worked, anyway! Pulled the switch panel and found a mess- every wire had at least one splice between panel and wherever it disappeared to; many different kinds of wire, some unsuitable for the application; no labels or numbers, all snarled so badly it looked likel a poorly made bird's nest. The battery connections had been much the same- splices, different kinds of wire. My plans are to replace all wiring, replace interior lighting (and add a couple) with LED lights, replace whatever running lights I can't get to work, add an anchor light, move the switch panel to the console over the galley so I don't have to be a contortionist to see what I'm turning on or off, install the am/fm/cd I got Christmas, and put in a new battery and charger. Hope the VHF radio and depth sounder and be resurrected. Naturally, I want all this finished by spring, the sooner, the better. I also need to deal with a shrunken bolt rope this winter- makes for an ugly sail. Should I get this all done, I'm sure to find something else to prevent boredom. If this qualifies as a New Year's resolution, so be it. It's early, but ... Happy New Year to all.
