Dang, I broke the hinge (flange) off at the bottom-mast plate through which you place the pin that attaches the mast to the plate on the deck (you might call this plate on the deck a tabernacle, but it is just really a plate with two flanges sticking up that have holes to match the hole in the mast-base plate). Photos below. I've look in owners manuals, and search the internet for help without success. Questions: (1) what is the technical term for the mast-base plate, (2) where can I get a replacement mast-base plate, (3) the old plate is secured to the base of the mast with 2 screws in the front (which I have NOT been able to turn with even the largest screw driver to take them out), and on the back side by 4 rivets through a flange on the mast-base plate that is used to attach the vang to the base of the mast. I assume I can drill the four rivets out on the backside, but how do I get the screws out of the front portion of the plate without damaging the mast (i.e. widening the holes in the mast) so that new screws with new mast bottom plate will be secure in the mast, and (4) any suggestions as to how to go about this entire procedure. Hard to express how depressing this is as I had just set up my rigging for A-spin with help from this forum and hoping to get the boat back in the water after two years on the hard.
