OK, so the Stargazer still has her original Barlow 2 speed winches from 1983. I have been saving up to replace them with self tailers, but other projects keep sucking up the boat bucks. A couple of weeks ago I noticed a small crack in the top of the port winch's drum. I couldnt see much as they have Barton Winchers on them, but it seemed minor, and with replacements on the horizon I ignored it.
Last night during our beercan race, I noticed that the crack had enlarged. I also inspected the starboard winch, and noticed that it too had a small crack in the top of the drum.
So now I am in a pickle as the funds for the new/used winches are not there. I am thinking of trying to repair the old drums. Here is my plan:
This is what that would look like.
Stop the crack:
Weld it closed.
Do you think this will work? Any other Ideas?
- Remove the Barton Winchers from the drum for better inspection.
- Disassemble winches
- Drill relief to stop the crack from expanding.
- Dremel a bevel along the crack.
- Heat the drum with Map Gas torch.
- Fill/repair the crack(s) with Alumiweld Low Temperature Aluminum Welding Rods
- Grind/sand smooth
- Reassemble the cleaned and serviced winch parts
Stop the crack:
Weld it closed.
