as bad as this one is, im sure the generic prices online are far from what the actual cost would be.That's been my whole point- depending upon where the boat is in Florida; a diver might be relatively cheap or quite expensive (assuming one considers $200 to clean a 20' boat expensive.) But as a hull cleaner, my guess is wherever the boat lives, hiring a diver would be on the higher end of the scale.
I once used a sidewalk scraper on a MacGregor 26 that was in a similar situation. In the water for years with no bottom paint. Regular handheld scrapers were simply not up to the job.I have 2- stiff 3" scrapers and one 6" not quite as stiff scraper. all of them are metal. I will be stopping to pick up some gloves this afternoon. the current owner said he has some long handled scrapers as well. anything else that would be useful?
I will be trailer sailing, at least for a while. blisters are not a huge concern as long as its not too bad. blisters are FAR easier to repair than replacing the entire deck, as would be required on my current boat!!Yes just go for it with a nice metal scraper and see what is under all that
growth and if you see any blisters just do search on repairing blisters.
If in hurry to use for the season just scrape and some sanding,some trailer
sailers don't even add bottom paint.
Are you planning to trailer or leave in a slip,if trailering.
Nick
I like it! I may go pick one of those up as well! How did your experience go with the mac? did it turn out alright? how long did it take you to scrape the bottom of the majority of the growth?I once used a sidewalk scraper on a MacGregor 26 that was in a similar situation. In the water for years with no bottom paint. Regular handheld scrapers were simply not up to the job.
I shortened the handle by half to make it easier to use underwater.
I probably spent an hour on that boat. It was entirely encrusted with large shelled animals including barnacles, oysters and mussels, not to mention very thick soft growth as well. If your boat is anything like this one, you will not get a real good view of the actual gel coat surface after the cleaning. There will simply be too much shell base and hold-fast material remaining that you probably will be unable/unwilling to remove while the boat is in the water. Do not expect to have a nice clean bottom after you are done.I like it! I may go pick one of those up as well! How did your experience go with the mac? did it turn out alright? how long did it take you to scrape the bottom of the majority of the growth?
No. That was a practical impossibility and not my goal in any case. The owner simply wanted to put the boat on a trailer and take it home so he could work on it there. I told him what to expect (much as I have you) before I started the job.good info... did you ever get the bottom of that boat actually clean?
thanks Bob! nothing beats a GOOD excuse for a new tool!!!When you get the boat home try an "oscillating multitool" from Harbor Freight with a flat metal blade. I have seen them used to clean up a boats bottom. Not very heavy to hold up. Seemed to work quite well, removed loose bottom paint too, with no damage to the gel coat. It also has many other uses on board a vessel.
Good luck, Bob
http://t.harborfreight.com/power-to...cillating-multifunction-power-tool-60428.html
Now that I think about it, I've seen scraper blade attachments for a reciprocating saw, too. Home Depot or Lowe's had them, not sure which.thanks Bob! nothing beats a GOOD excuse for a new tool!!!
