removing bottom growth
Dec 19, 2006
5,832
Hunter 36 Punta Gorda
Blisters
When a boat is left in water and warm water in Florida it has a very good
chance of having blisters and that is going to be a lot of work.
A diver will charge much more for a book that was neglected that long and the more it needs cleaning the more time cleaning will be charged double and that is
if a diver is willing to get involved with that hard a job.
If no blister found than scraping and than sanding and new bottom you could save alot of $$$$.
And if trailering it is not going to be much of a problem in the future because
on a trailer will allow the hull to dry out and less chance of problems.
The problem with boats in florida is they stay in the water for 1 or 2 or even 3 or
more and the hull does not get a chance to dry out and if the hull doesn't
have protection the hull will develop blisters.
But if on a trailer in your drive way you can save lots $$$$.
Nick
Apr 1, 2010
398
Cal 33 and Sea Pearl 21 . Crystal River, FL
it will be on a trailer in my yard for a while. if it ever goes in a slip again it would get a proper bottom job. I have gotten a lot of good opinions from everyone as well as getting to watch the entertainment of who's **** is bigger LOL
I think the bottom line is that I will just have to check it out myself. if I had known a diver was that cheap, I probably would have gone that route instead. lessons learned....
Apr 1, 2010
398
That's been my whole point- depending upon where the boat is in Florida; a diver might be relatively cheap or quite expensive (assuming one considers $200 to clean a 20' boat expensive.) But as a hull cleaner, my guess is wherever the boat lives, hiring a diver would be on the higher end of the scale.
as bad as this one is, im sure the generic prices online are far from what the actual cost would be.
Sep 30, 2013
3,595
Soo ... is there any specific scraping tool of choice, when doing this job the old fashioned way??
Feb 26, 2011
1,440
Achilles SD-130 Alameda, CA
It's gonna have to be metal, relatively sharp and heavy duty. If there is significant shelled animal fouling, some damage to the hull from the scraper can be expected.
Dec 19, 2006
5,832
Agree
Yes I think hull cleaning here in west coast Fl does vary and
prices will depend on how often the boat is cleaned.
if done every 6 or 8 weeks the price will be less.
Like anything else if it is done often it is a quick job
and will cost less.
Nick
Nov 26, 2008
1,970
Endeavour 42 Cruisin
Impossible to guess the cost of a diver. Many I've encountered charge much more for a one time vs regularly scheduled. Some charge by the foot and some charge by the hour. Most, when they see heavy growth, will charge extra. And base rates are variable even within Florida.
Apr 1, 2010
398
I have 2- stiff 3" scrapers and one 6" not quite as stiff scraper. all of them are metal. I will be stopping to pick up some gloves this afternoon. the current owner said he has some long handled scrapers as well. anything else that would be useful?
Dec 19, 2006
5,832
Scrape
Yes just go for it with a nice metal scraper and see what is under all that
growth and if you see any blisters just do search on repairing blisters.
If in hurry to use for the season just scrape and some sanding,some trailer
sailers don't even add bottom paint.
Are you planning to trailer or leave in a slip,if trailering.
Nick
Feb 26, 2011
1,440
I once used a sidewalk scraper on a MacGregor 26 that was in a similar situation. In the water for years with no bottom paint. Regular handheld scrapers were simply not up to the job.
I shortened the handle by half to make it easier to use underwater.
Apr 1, 2010
398
Nick
I will be trailer sailing, at least for a while. blisters are not a huge concern as long as its not too bad. blisters are FAR easier to repair than replacing the entire deck, as would be required on my current boat!!
Apr 1, 2010
398
I like it! I may go pick one of those up as well! How did your experience go with the mac? did it turn out alright? how long did it take you to scrape the bottom of the majority of the growth?
Feb 26, 2011
1,440
I probably spent an hour on that boat. It was entirely encrusted with large shelled animals including barnacles, oysters and mussels, not to mention very thick soft growth as well. If your boat is anything like this one, you will not get a real good view of the actual gel coat surface after the cleaning. There will simply be too much shell base and hold-fast material remaining that you probably will be unable/unwilling to remove while the boat is in the water. Do not expect to have a nice clean bottom after you are done.
Apr 1, 2010
398
good info... did you ever get the bottom of that boat actually clean?
Feb 26, 2011
1,440
No. That was a practical impossibility and not my goal in any case. The owner simply wanted to put the boat on a trailer and take it home so he could work on it there. I told him what to expect (much as I have you) before I started the job.
May 16, 2007
1,509
Boatless ! 26 Ottawa, Ontario
When you get the boat home try an "oscillating multitool" from Harbor Freight with a flat metal blade. I have seen them used to clean up a boats bottom. Not very heavy to hold up. Seemed to work quite well, removed loose bottom paint too, with no damage to the gel coat. It also has many other uses on board a vessel.
Good luck, Bob
http://t.harborfreight.com/power-to...cillating-multifunction-power-tool-60428.html
Apr 1, 2010
398
Good luck, Bob
thanks Bob! nothing beats a GOOD excuse for a new tool!!!
Feb 26, 2011
1,440
Apropos of something (or maybe nothing), this brand spanking new Andrews 28 is doing the Singlehanded TransPac in a week or so. Against my advice, the owner is keeping it in the water in Alameda with no anti fouling paint, only an epoxy barrier coat. Thus, I am cleaning it every 3 to 4 days. And in that time, every single square inch of wetted surface begins showing visible fouling growth.
Sep 30, 2013
3,595
Now that I think about it, I've seen scraper blade attachments for a reciprocating saw, too. Home Depot or Lowe's had them, not sure which.
