Reefing Lines in the Boom
1
Pearson 33 Port Aransas
1986 Pearson 33 -- I am trying to run the lines thru the boom for the reefing system for the mail sail.
Does anyone has a diagram of how to run the lines using the two (2) pullies in the boom.
Hunter 25_73-83 NORTH POINT MARINA/WINTHROP HA IL
reefing lines in boom
Go to Pearsoninfo.net under model 36-2 maintenance notes. This has the Rigrite diagram of internal reefing lines for an Isomat boom. .. same as many others. Question? Why do you want internal reefing lines when an externally mounted reefing system is more easily maintained and any problems easily fixed? Internal reefing lines are also prone to jamming and catching on interior surfaces of the boom if any screw\bolt heads are not flush with the surface. Also, the sheaves in the blocks are very susceptible to galvonic/salt corrosion due to the humid interior environment and eventually will not turn freely. I am in the process of reconditioning my Isomat boom, a considerable project, and much prefer the external jiffy reefing on my previous boat. Best, Rognvald
NYSail
Jan 6, 2006
3,184
Beneteau 423 Mt. Sinai, NY
I removed the original set-up for the internal reefing system. I removed the block and have a solid line running straight through...reefs wonderfully. Can't really understand why the block set up other than to make it more complicated than it needed to be...Goor luck!
Greg
Mar 20, 2009
15
Pearson 32 Liberty Bay-Poulsbo, WA
Go to Rigrite.com They have many parts etc. for the spars pearson used as OEM. Chances are you can find what you need and it will be simpler than trying to reinvent the wheel.
Pearson 26W Marblehead
Internal reefing.
I agree with rognvald. Why look for trouble and jams you cant see.
A 2 line external jiffy reefing system is easy to install and trouble free.
