I have replaced the 2nd reefing line twice on my Hunter 50 Tall Rig with single line reefing. The first reefing line has not had any issues. The line seams to be being cut where it exits the small hole on the goose neck. After leaving the goose neck the line goes to the reek tack clew as per diagram attached. Both reefing lines are the same size and the holes are similar. Has anyone else had this problem? Is there a cure?
It is surprising that there is no block at this point but merely a rounded relief at the top of the hole.
