- Oct 22, 2014
- 23,789
currently using a hook at th tack, and a reefing line on the clew. Much simpler line routing, and I think a way better reef.
They jam when reefing, not when shaking out the reef. The boom position affects the opposite side of the block when shaking out the reed, which has not been a problem.It looks like the blocks don’t swivel with the boom so maybe the line tends to jam if the boom is off to one side, as may be the case while reefing?
They’re there to lead the lines from the tack properly into the boom sheaves. The lines can only enter the boom from below, and so must be run through a block below the boom.Are they adding purchase? Might be better to first ascertain why they are there.
Is your setup fairly identical to mine, spacing wise between the offending block and the tack cringle? Have you had any similar issues with that block jamming when reefing? If not, it may be my simplest solution is to replace the reefing lines. Would smaller diameter lines be inadvisable in my case?I have those same blocks on my mast, and I think that they are required (or something similar) to reroute the lines as they come down from the tack cringle If you are sing single line reefing. You can’t run them into the boom from above…so they run down to the block, reverse direction and go up into the boom neck.
A couple of blocks at the bottom of the mast way work better if you have room, but I don’t know why the current blocks wouldn’t work.
I have gone back and forth on single line reefing, currently using a hook at th tack, and a reefing line on the clew. Much simpler line routing, and I think a way better reef. Yes, I have to go to the mast to put in or shake out the reef, but I don’t mind that..I usually put in the reef before I leave the dock if I am in doubt.
Greg
Not at all.Would smaller diameter lines be inadvisable in my case?
Mine is fairly close to your set up.Is your setup fairly identical to mine, spacing wise between the offending block and the tack cringle? Have you had any similar issues with that block jamming when reefing? If not, it may be my simplest solution is to replace the reefing lines. Would smaller diameter lines be inadvisable in my case?
It is called a messenger line. Use any small diameter line attach it by sewing and taping and then pull it through. I have some 3mm Dacron or 3/16" braided dacron flag halyard line. Polyester line is better than nylon because it doesn't stretch. Sometimes the connection will get hung up and a nylon messenger line will stretch rather than pull the halyard through.Refreshing this, as we’ve had other projects that took priority. Washing the lines seems a relatively easy first thing to try. However, the lines do route through the boom, and I would have no idea how to re rig them once removed. Can I attach another line to the end to route through the rigging and leave as a placeholder that I can simply reverse the process in order to rerun the reef lines, once cleaned?
The lines are properly sized (rigging specs call for 3/8”). I will wash these. I would also like to install a fairlead as @capt aj says. The outer edges of the sheaves in the offending block are 1 1/4” apart, which indicates to me that should be the width of the fairlead. I am having trouble finding a fairlead that would work though. It needs to attach to the mast (clearly). I can drill and tap it, or could mount on the track (if such a fairlead exists). Does anyone have any suggestions?I believe your problem stems from the lines not leading in at the proper angle. You want a fair lead into the block so the line stays on the sheive at all times.
First, the "spec" for size is based on the recreation quality cordage that production boat builders package with their new boats. So you should be more concerned with strength limits and job requirements, and compatibility with the hardware. As those lines age out in the sun and weather, they're going to swell and stiffen so they won't run as freely as they should. Going a bit smaller would reduce the increased friction.... as long as the new lines are consistent with the recommended working loads and they fit the boat's hardware. Always check for fitment first. All the online chandleries will have strength charts for the rope products they sell.If spec is 3/8”, is it inadvisable to switch to 5/16”?
Mast is Aluminum, and the screw/bolt is stainless steel?Not sure what’s best for securing the block to the mast.
www.practical-sailor.com
