I am still doing upgrades and repairs to my recently acquired 1984 Hunter 31 and my latest project is to get all the cabin lights working. As luck would have it, most of the ones that were not working only needed the switches to be worked 15 or 20 times and one needed the bulb contacts cleaned so they are all working but one. That one is in the V-berth on the stbd side, nothing seemed to work so I removed the fixture and cut the wires in order to check for power only to find there was none. There are two green wires which marry before going to the light as does the two black wires so I assume the extra leads go to another light somewhere but I don't know where since all the other lights are still working after cutting the wires. The wires go into that cavity which runs from the bow right back to the galley. I would be very grateful if anyone can shed any light on this matter (pun intended). If all else fails I will just buy a stick-up LED light for that location.Also. does anyone have a source for those cone-shaped 12v light bulbs with the bayonet socket? Thanks a bunch guys. Reg
