Reading light problems
Reg M
May 21, 2016
131
Hunter 31 Montague
I am still doing upgrades and repairs to my recently acquired 1984 Hunter 31 and my latest project is to get all the cabin lights working. As luck would have it, most of the ones that were not working only needed the switches to be worked 15 or 20 times and one needed the bulb contacts cleaned so they are all working but one. That one is in the V-berth on the stbd side, nothing seemed to work so I removed the fixture and cut the wires in order to check for power only to find there was none. There are two green wires which marry before going to the light as does the two black wires so I assume the extra leads go to another light somewhere but I don't know where since all the other lights are still working after cutting the wires. The wires go into that cavity which runs from the bow right back to the galley. I would be very grateful if anyone can shed any light on this matter (pun intended). If all else fails I will just buy a stick-up LED light for that location.Also. does anyone have a source for those cone-shaped 12v light bulbs with the bayonet socket? Thanks a bunch guys. Reg
Mar 2, 2008
406
Cal 25 mk II T-Bird Marina, West Vancouver
I replaced all of my interior lights with sealed LED units (c/w switch) from CT (Canadian Tire RV section). They may not be as bright a some marine units but are a best buy at ~ CDN$15 each and 0.1 amp consumption. I did install a couple of bright soft white adjustable LED reading units (with switch and LED bullet cluster bulb) from the local marina store at ~ CDN$45 each for when you need lots of night but seldom use them. p.s. I also replaced all of my navigation lights to LED. My typical consumption now is less than 10 amp/hrs per night including soft music.
Nov 6, 2006
10,256
Here is a copy of the original wiring diagram for the H-31. The stbd side Vee lamp is last in line apparently and is being fed from the stbd "eyeball" lamp that is stbd side, just aft of the head bulkhead..
Reg M
May 21, 2016
131
Hunter 31 Montague
Thanks for the wiring diagram, I am sure this will help. I am hoping I can attach a string to the wires and pull them out at that light aft of the main bulkhead then use the string to pull new wires in. I have saved the PDF for future use. Thanks again.
Reg
Dec 28, 2014
61
Hunter 280 Mandeville, LA
Just a heads up on bulbs. Walmart has a large selection of LEDs, go to their online site and search 'auto led' and tons will come up. Excellent prices, maybe not marine rated but I have used them without problems.
Reg M
May 21, 2016
131
Hunter 31 Montague
I got a really good deal on Ebay from a supplier in China, 8 LED cluster lights for $10. Was unable to pull those wires out so I will install a battery operated LED for that one location in the V Berth.
