Raw water strainer
Jul 29, 2009
1
2 Capri 14.2 Home
Where is the raw water strainer on an O'Day 302? I see the hose comes out from the thru hull into the fiberglass pan. Then it exits at front of the engine to the water pump. I don't see a strainer.
@sailcraftri If you can see into the bowl and there is no strainer, then there is something missing in the bowl. Pictures of such an anomaly are always good to post.
Good chance there’s not one. Oday 28’s built just before the 302’s didn’t have one. Seaweed or any other debris would occasionally collect in the heat exchanger.
Oct 29, 2017
88
ODay 302 Kenosha WI
I have a oday 302 and it does not have a raw water strainer. A Scoop install installed in reverse was all it has. I am in the process of installing a Groco strainer. It is a tight fit. I did check the heat exchanger and it was clear so seems like the scoop is working. The boat is on Lake Michigan so not too much of a concern.
Jan 7, 2011
4,777
Oday 322 East Chicago, IN
My 1988 O’Day 322 has a Groco strainer between the thru-hull and the water pump. Located near the stern tube.
Greg
Feb 22, 2010
70
Oday 322 Delaware River
Your boat likely does not have one. My O'Day 322 went 30 years without one, apparently.
I liked the Vetus strainer some of the new boats I deliver have installed, so I installed one for my own boat a year or two ago. Very easy to check and clean out. See pictures.
Likes: Ward H
Suri
Jul 2, 2021
11
O'Day 302 Chicago
AndreNJ11, thank you for those very clear pictures. You are an inspiration to keep the engine clean in my 302.
Jan 7, 2011
4,777
The Groco on the right is for the head, and the one on the lower left is for the engine strainer…
