After months of redoing the deck, trying to re-install a small, square based 1 3/8" x 1 3/4 inch "Perko Flush Ring Pull" for my anchor locker (see attached sample of similar product). I really don't want to muss up the beautiful new deck regretted fresh hole!
QUESTION: Drill all the way through the hatch to insert the pull ring OR somehow "gouge out" the circular/spherical hole on the underside of the pull ring required?
And, if I don't drill all the way through, what tool/bit do I use to make the required "gouging" hole?
In other words, when I open the hatch, should I see a hole all the way through the lid with the underbelly of the latch hanging slightly hanging into the hole or just see the fiberglass? The hatch is probably just a bit thicker than the latch would.
I know this is a small question in a world of Big Questions, but I need someone else's point of view. Thank you for any help!
I've attached a sample part diagram from similar product to mine.
