I find that a spritzer/spray bottle provides plenty of water and I only use electric random orbit power sanders, on an aluminum ladder to add to it.As Capt. Wayne said, the Harbor freight models have worked fine for me. I did splurge though and get the $49 model.
A little off topic for this thread, but I just finished the topsides gelcoat on my 1970 O'day Mariner and was beside myself with satisfaction at how it turned out.
It looked pretty bad and was a "last shot" before considering painting. It had sat outside, uncovered for 5-8 years.
As the gel coat was chalky as well as stained, I used an air powered DA sander with a hook and loop pad. I cut green ScotchBright pads into circles and stuck them on. I scrubbed the entire topsides with that and a strong solution of Simple Green.
The green pads are close to about a 600 grit. I then followed up the same way with the grey pads which are about 1200 grit.
It cleaned all the stains, and removed the chalkiness.
PLEASE, Air Power ONLY with the above method, DO NOT USE an ELECTRIC SANDER with WATER!!
Then compound and polish.
Even on my 20 footer it was about 40 hours work, initial wash to finish wax. I followed up with "Woody Wax" as it's not as slippery, then used 3m Marine wax on vertical surfaces and areas not walked on.
I have to say it worked out great. Boat looks new, literally.
Anyone considering painting their topsides should give their gelcoat one more chance, as once it's painted it's painted forever.
Not too bad for nearly 45 year old gel coat.
Rob Jones
Fork,Md
I would not use a running hose, but a spray bottle is going to apply no more liquid to the work surface than this fat guy sweating.... I am that sweaty guy, at least until I get used to the humidity of the season
Without soaking things, know that wet sanding with a hand pump spray bottle is going to be for all practical purposes safe.
My $.02
