Port Replacement
wbuckl
Oct 30, 2011
1
Peason 36-2 New Bern
Am upgrading my Pearson 36-2 (love the boat!) Any advice on replacing all ports. Are drop in replacements available, has anyone switched to metal ports, aluminum or stainless!
Hunter 25_73-83 NORTH POINT MARINA/WINTHROP HA IL
Replacement ports should be Bomar. Good luck and good sailing, Ron
NYSail
Jan 6, 2006
3,184
Beneteau 423 Mt. Sinai, NY
Depending on the year... My 1986 P36-2 has Beckson windows. All sizes are still available. I just replaced all the opening ports. Did the screens and gaskets when I bought her. I am pretty sure latter years used Bomar.
Good Luck
Ariel
Feb 1, 2006
279
Pearson 36-2 Houston, TX / Rock Hall, MD
The 1987 and later have Lewmar ports. I don't remember the hatch maker but I believe it is Bomar, not that it matters.
wbuckl, Lewmar still makes the alum. ports and they are avaliable from the SBO store here. If you have a 1986, check the cut out dimensions to find out if they will work. The Lewmar site has all the dimensions.
Dave
s/v ARIEL
