Jeff
Bought an older C27 last year. When I removed the boom I found a thin threaded bolt with a nut being used to secure the boom to the mast. This is the kind of bolt you would use to secure the handle to a child's wagon. What should be in its place? Is it called a tack pin? If so, where can I get one? A marine supplier or should I get it from Catalina?Jeff
