- Jul 24, 2006
- 628
its raining and dismal in "sunny florida" this morning, so the question...The Morgan 33 outisland has a outward flanged hull-to-deck joint. The po removed the rubber rubrail probably due to being chewed up from the dock. I am planning on glassing the joint on the inside for strength and water tightness while i have the bulkheads out. My question is what do i cover the approximately 1 to 1-1/4 inch flange with that will hold up to bumps and scrapes without splitting or rotting. I am not sure if i can even get the original heavy rubber rail and if i could find it it would probably be cost prohibitive. I was thinking about maybe plasteak kind of stuff screwed in from underneath, or wood then some off the shelf rubrail? I even thought of using firemans hose that i would split on the table saw? Any ideas would be greatly appreciated, thanks. Patrick
