Lol...thanks Stu. I briefly went at it with a screw, but decided to step back after a couple of hours. Will try again though...Solstice, I forgot...a long thin sheetmetal screw. If it won't pick out, screw the screw in and use pliers to pull the screw back out, with packing twined into the point. Doh, it's always my first step and I forgot it. Thanx for helping me remember.
Now, where were those...???![]()
So true! 25 years of DYI on 4 boats and this ranks as one of the worst jobs. Last Spring I rebuilt my head and would rather do that job any day. Had a PSS on my last boat (which I installed) and figured I’d go with a traditional box on this one because separating a shaft from the flange is equally painful...now I’m not so sure.Anything that you can shove in there to loosen it will do.
I used a screwdriver...and it was well lubricated after having been immersed in my cursing and swearing for multiple hours trying to remove the old packing.
I’d rather eat my own feces than do that job again anytime soon.
If only I could be so lucky.So your saying it is a long slow task requiring persistence and patience.
Sounds a bit like sailing in a 4 knot breeze.
At least you guys are not trying to do the work beneath the engine as in the v-drive arrangement.
Sounds like you need to have a beerView attachment 163055
I’m on hour 5 and figure I have about 70% out. I’ve used everything mentioned here as far as tools (17 at last count). Next headache will be cleaning the thing to take the new packing.
I was initially very careful not to ding the threads until I realized I only need the first 5 or 6.
This is what I started with
A tool rental place may have a thread tap large enough. At least it's not metric, they're impossible to find even up here.Now just gotta figure out how to clean up those threads in the nut![]()
Thanks Leslie. I actually think the integrity of the threads are okay. However I need to get the first 5 or 6 turns cleaned up from the flax remnant and turning smoothly so I can be sure any pressure when tightening is from the new packing and not the threading so I don’t over tighten when adjusting.Thread restoring files also work well for buggered threads. Some times better tan taps. Also com in metric.
Only a 1/4” clearance between the nut and shaft. I just went down to the boat and wiped some WD 40 on and used my angled pick. Got 90% off and it spins on fairly easily. Coated it one more time and will let it sit for a couple days before I go at it one final time with the pick. I still have a couple of turns with some resistance and I really want to get rid of that so I know I’m tightening the flax and it’s not the threads that are resisting. Thanks for the tips!Why not use a brass wire brush. And pick what it misses.
Should be just fine there, too. I use it on the lock nut and the open threads, never have bothered to put it inside the gland.I use Lanacote on the lock nut threads for ease of removal but that stuff is a bit to viscous for the packing threads I think...
