Owning a boat sucks!
N
NC-C320
Line & Cleat Failure
Hermit,
Something is wrong here. First of all, previous posters' advice regarding moving to more sheltered waters closer to home is good advice. Neither, you or your wife have any, repeat any, sailing experience, yet you have the boat in a location notorious for high (rough) wind conditions according to other posts. You aspire to cross the open gulf on a offshore passage vs. using ICW/coastal shore hopping with a boat that can't even be properly docked in an exposed marina wiithout damage. Driving a long distance just to motor just a few hours is not sailing. The motoring and practicing docking in itself is good.
But what is going to happen in high wind sailing with sails, while trying to learn, is, I am afraid, going to be similar to your experiences with damage to boat just in the slip, except it's going to be more serious and potentially deadly. You need to get the boat to a calmer area to learn to sail...otherwise, you are going to risk not only your boat and money, but your life. And if this is not possible, get an experienced sailer to go with you to teach you how to sail. This would be someone who may know how to avoid dangerous incidents, and if they occur, know how to respond. Learn in water where the winds are not so high where mistakes are not going to hurt someone or damage the boat. This is especially important if you are intent on learning by yourself (that's how I did it also, but I carefully picked relatively calm conditions on a river well away from open ocean). A sailing course for you and your wife would be an excellent way to accelerate the learning curve, but is going to cost money. If you have never sailed, how do you even know whether you will like sailing, much less whether you really want to cruise offshore. Maybe the horse is ahead of the cart here. I had an aquaintance who longed for offshore cruising and had lots of experience sailing rivers, bays, and sounds. He knew how to sail, loved sailing, and had owned several boats. He got a chance to crew on a offshore delivery of a boat, and found that he got terribly sea sick in the open ocean, and that was the end to his open sea cruising. He continued to sail inshore and loved sailing. The point is that before you commit too much money to this venture, learn first hand what it is you are getting into if possible, or work up to it slowly. And the advice regarding your wife was well taken. You have to make sure all these problems, time, and difficulties, plus the many sailing misadventures to come in rough open water while learning don't turn her off to sailing. If it does, you will have a difficult decision to make: Stay on shore with wife and not cruise the islands, or go without the wife....neither is very good.
Now the lines and cleats. There are lots of Catalina 30's out there. Most don't routinely have cleats pulled out of the decks. Neither do other boats. Also, other boats in the marina remained tied up without lines breaking or boats hitting pilings. You don't mention having severe storms, but you do say there is damage each time you go to the boat. Your marina seems to be exposed, so that is enough reason to move sooner than later if you can't keep the boat there safely. Also, from your post, you and your adjacent neighbor suffer serious damage, but other boats in the same marina apparently don't have damage. What are they doing that you are not. I doubt that your exposed slip is significantly different from theirs in the same marina. Study very carefully to see what they do differently from you, and adopt those successful techniques. Get good quality nylon lines (2x 1/2" per cleat minimum given your rough location). Tie them so they don't chafe one on the other. Tie the lines securely to the pilings so they don't slip down the piling and become prematurely tight, leading to early failure. Cross your stern lines and tie the boat so that you can take increases/decreases in water level...while tide may or may not be an issue, when winds increase, they cause additionaly wind tides that could make your lines go tight while you are away. This could create enough force to pull cleats out or to break lines. Use the rubber snubbers if you like, but over time, they tend to degrade and break (I don't use them). If you have chafe points that can't be eliminated, use chafe gear that that absorbs water to keep lines cooler internally. On chafe points, a smooth round bolt head is enough to chew a line apart in just a little time if the line is tensioned under high load, so watch your line leads at all points that the wind can come from (360 degrees). Your lines could be tied fine for one wind/wave direction and totally unsuited for another direction. As an engineer, you should be able to visualiize this easily. If there is large/big boat/ship traffic close by, they kick up terrific wakes even when going slowly and could cause you problems. Finally, don't forget nylon line stretch is good for absorbing shock, but it can also be harmful if there is too much stretch, so that you get against the pier. Stretch increases significantly in high winds, well over what you might think in calmer conditions. Actually, I use doubled up double braided lines vs. three strand to minimize stretch for this very reason.
If seems that neither, you, nor the adjacent boat are doing things correctly. From what you have said, I don't think anything (boat, barge, etc.) struck you boat. If so, there would be obvious contact damage on the hull and other deck fittings...bent rails, etc.
I hope this is helpful, but I have an idea that you will continue to charge ahead blindly in your own way, and if so, there will be more tales of misadventure. But those do make good sea/shore stories and attract attention from well meaning posters on forums like this.
Best of luck...get some sails and go sailing, preferable with experienced sailer at first, and in calmer conditions.
Dec 9, 2008
426
1980 Hunter 30 "Denali" Seaford, VA
Sorry to hear about your boat! I can't imagine your disappointment but hang in there. My wife and kid's and I get so much enjoyment out of the sailboat. I never realized how much wind you guys get down there in CC to get battered like that without sever storms, any idea what the windspeeds were around the time this happened? I hope that you are able to get out of that slip soon and hope the new one is better protected.
Rick D
Jun 14, 2008
7,183
Encouragement
Yea, bad stuff sometimes happens. But, you have done a lot in a short time and accomplished much. As far as the damage, locals will let you know what works and does not. My dad had a boat in San Diego in an area notorious for surge. It was so bad, snubbers were required on all dock lines and the lines lasted no more than a year. The boats moved so much, the masts would hit if they were not offset from each other. Cleats loosened over time. It was too rough for them as they aged despite a great view.
You'll do a good job fixing the damage and it will probably be better than new. Your neighbors will let you know if you should stay or move and will have their own suggestions for docking. By the way, there was significant damage to boats in my dad's marina from a navy patrol craft on an intercept run. And, on my YC marina, $25K damage to docks was caused by one police boat running through the harbor at full throttle. And, those were good floating docks. FWIW.
May 11, 2005
3,431
Seidelman S37 Slidell, La.
Need to determine
Hermit,
You need to determine whether the dock lines broke, or chaffed through. It takes a hell of a lot of force to break a 1/2" dock line. From the posts you have made I don't think you would have purchased really cheapy line. If chaffed through, then a piece of garden hose over the chafe points will help. But that still doesn't answer the clete problem. Unless they were not backed up at all, shouldn't have happened. Make sure you have nice big backing plates on the cletes, good high quality lines, some kind of chafe prevention, and use some spring lines if you don't have them.
Dec 19, 2006
5,822
Hunter 36 Punta Gorda
Sounds
When I was younger and did not know how to swim I jumped into 10' of water and almost saw my life go by,soon learned to start off in 4' of water until I learned how to swim.
I would move the boat some place calmer even if in a lake until you get some sailing experience and your wife gets a smaller taste of sailing,sounds like conditions you have is going to scare the shit out of her when you get to go sailing with all that wind.
My wife started with me on Hobie cats and I did my share of flipping them,now we have a 36 Hunter and when the wind and conditions get nasty she still gets real nervous on our boat and rather not be out when the winds are heeling us over,so I reef to keep the boat flatter and she is much happier,if it's really windy I leave her home for better days rather than scare,she did a three week cruise up in New England on our 36 and she had except for a little sea sickness once,I do what needs to be done to keep her sailing with me.
I am planning trips to the keys and don't want her to chicken out.
Don't give up but maybe change things and go slower into your dreams.
Nick
2,288
C30 Event Horizon Port Aransas
NCC320-"I hope this is helpful, but I have an idea that you will continue to charge ahead blindly in your own way, and if so, there will be more tales of misadventure. But those do make good sea/shore stories and attract attention from well meaning posters on forums like this." WTF?- if you don't want to read or respond to my posts then don't. Go respond to whomever you judge to be "well meaning posters". Aren't you the guy who had to change your identity on here, I will tell you why; you post nasty things and piss people off.
Easy and Rick- Sail dog said something about a bowline knot making the rope weaker. It looks like it may have broke near a knot that I tied. But I am not sure because someone benevolently tied my boat back up to prevent further damage. The marina I am in has a seawall that shelters pretty well from the big waves caused by the wind. There could have been a wind shift that brought waves in through that opening though. I am calling today to see when I can get into a better marina. When I Go back down this week I will move further into the marina and bring new dock lines.
There is some old fire hose looking stuff coiled up at the marina, it appears to be take what you need.
The line I used was 1/2" nylon anchor rode. I have hundreds of feet of different strength bungee cord. I think I could come up with something, but no one else uses anything like that and they seem to be ok except for the guy next to me.
Next time I go down, which will be in the next few days, I will take some pics of how I am going to tie it up. What is a spring line exactly? Is it a type of line or a configuration of rope.
Bythe way thanks for all the other posts about this problem I am having. I read through those, I don't know what a spring line is, but one idea I think I would like to try is backing into the slip. It seems to me to be the easiest way for me to dock single handed.
2,288
Seadaddler-you guys look healthy and happy.
I don't think I am rushing anything with the boat or sailing. I have actually been stalling a bit lately trying to get in better shape and get my business going better. There isn't another marina I can go to right now or I would.
Jon-the damage isn't that big a deal really. I haven't done anything to the boat above the rubrails so I am not too worried about it. I think I am going to everything above the rubrail with awlgrip or something like that, but I am going to make sure there is no water intrusion and get all critical holes potted.
higgs
Aug 24, 2005
3,708
Nassau 34 Olcott, NY
It does not sound like you spend a lot of time around your boat. I would suggest staying over on it for a weekend and hang around the docks and talk to some of uyour neighbors about what is happening. You will learn a lot.
Jul 20, 2005
2,422
Whitby 55 Kemah, Tx
So there aren't protective bariers to stop the waves from coming in the entrance? If so, wow...and to think I've heard some rave of the city marina down there.
Oct 26, 2008
6,249
Catalina 320 Barnegat, NJ
A spring line ...
is merely another set of dock lines configured to keep your boat from moving forward and backward in your slip. If you have simply a bow line and a stern line, you are explaining a lot of the reason for the failure. Your spring lines can be configured in a few different configurations depending upon the location of your cleats and the cleats on the dock. Basically, you should have a line from your bow cleat heading back to be secured on the dock near your stern. You also should have a line from your stern cleat heading forward to be secured on the dock near your bow. This is in addition to your bow line and stern line. Maybe you also have bow and stern lines on the opposite side from the pier (led to piles?)to hold the boat away from the pier structure. However, without the spring lines, your boat may have been surging forward and backward within your slip, putting a lot of stress on the two lines. You need to have more lines securing the boat. Every book on sailing will have a chapter dedicated to setting spring lines.
Dec 19, 2006
5,822
OK
Like already mentioned you need to spend more time around the docks and really see what's going on,maybe sleep over on the boat and ask around at the docks for advice what to do from people who have been around more.
When I first moved here in Florida the slips I saw how they were very different than what I had in NY,in NY nice full length floating docks easy to get off and on the boat with plenty of width,I could back in or when single handling just bow in and grap the spring line,here in Florida I was lucky I got the last floater but very short docks on both sides and narrow so when backing in its very tight and need to be careful not to bang into boats on both sides.
I have great dock neighbors that help out with advice and also helping with docking,I ask tons of questions all the time and tell them how new this Florida is to me so they all give plenty advice,the guy next to me is a liveaboard and also works on boats for a living and is great keeping an eye on my boat and giving advice setting up my lines.
My marina is very protected and don't have what you have,so hope you get every thing worked out and get to enjoy your boat.
Nick
Nick
luvitt
Oct 30, 2008
297
na na na
I got a cheap idea for the shaft & prop.... My boatyard guys have sworn to me that a "Marks-A-Lot" magic marker works better than bottom paint. I did not believe them. over a month ago I bet them a case of beer. Well, i lost. they hung an old plate piece of iron over the side that had one side ground clean and coated with magic marker. the other side was left alone. well we pulled it out last week and the the marker side barely had any fouling. just a little string of slime growing off it. the other side was coated with slime, juicy bubble looking craps, barnacles, NASTY! I believe them now. i have about 50 markers im gonna use on my shaft & prop. im too broke to buy paint! We foul pretty quick here in Charleston--2 weeks w/o protection and u r
s(rew3d. maybe u can apply it underwater?
2,288
Franklin-I am not at the city marina. I am at marina del sol, or harbor del sol whatever it's called. I think somehow it has two names. The city marina new floating docks are fantastic. The city marina wanted a longer commitment and I am on a waiting list at Port Aransas municiple marina. There are sea walls but the opening isn't completely covered. You can google map it and see what I mean. It is located a mile or so south of the city marina.
seadadler-there is only one other guy with a sailboat in my marina that uses it. The rest, 5 to 8 sailboats are derilict floating coral reefs. The boat next to mine has 6" of barnacles and slime on it. There are signs that someone does something with it, like fast food trash and the "great stuff" repair they did when the cleats were ripped out.
How do they sleep at night?
There are plenty of empty slips, I don't even have to ask to move. It's a pretty crappy marina, no amenities what so ever. But it's $100 a month, if I paid for a year I could probably get $50 a month. I bet all the slip rents added up don't add up to $1500 a month.
2,288
I am going to have my prop powder coated as a primer and then some kind of hard bottom paint. I wonder how long magic marker can do that?
2,288
brobbins- whatever you do don't paint your prop with bottom paint. But you probably know that from reading the posts here.
luvitt
Oct 30, 2008
297
na na na
yeah, dissimiliar metals cause corrosion. learned that a while ago. and being in the aerospace industry, it gets drilled in my head everyday.
The guys here swear it lasts. said they told a guy and he didnt believe and painted 2 blades with the high dollar stuff and 1 blade with magic marker. he owed them a case of beer too. Im gonna try it. no $$ for the real stuff anyway. plus i plan on checking weekly and coming back to this desert of a boatyard in december to do more maintenance.
Nov 2, 2007
14
- - Seabrook, TX
I would surely move the boat, now that hurricane season is here. If the marina is as bad as you say and you don't move... Well you won't have to worry about small damage anymore.
Jan 10, 2009
590
PDQ 32 Deale, MD
Please, sleep on the boat a few nights.
Very relaxing. And you will see how she moves.
Did I mention it was very relaxing... or can be if you don't give yourself a big to-do list... or at least a work pass between sun-set and sun-rise.
Jan 27, 2008
3,086
ODay 35 Beaufort, NC
Good Reading
Just a suggestion. Try to find a copy of Chapman's at a used bookstore, or maybe a used copy from someone like Amazon. I suggest used because the information won't change much with all the "editions" so an old one will still have good info. You can probably find one for under 10 bucks. This is considered the "Bible" of sailing (at the risk of sounding sacreligious). This will provide information on everything from spring lines to docking techniques, to how to properly display flags, anchoring, etc. You can learn a lot by reading as you've seen here. Just another source of good information you can keep on board. The other good book is "The American Practical Navigator" by Bowditch but this is a lot more theoretical and Chapman's should be the first book to have on board.
Dec 27, 2005
500
Hunter 36 Chicago
http://www.tropicalboating.com/boat-handling/spring-lines.html
Scott,
Here's a link to a website on spring lines. Lots of info on the web. Don't feel bad, I didn't know what the heck a spring line was either when I graduated to a larger boat. The club I belong to requires spring lines whenever tying up to the dock. BTW, any info I find useful on the web I'll print out and laminate so I always have handy in case I forget something. Comes with age I guess (the forgetful part).
