Thanks BrianS.Hey, Finding41… there are battery operated tachometers that can provide hour meters.
I have this one: http://www.amazon.com/Tachometer-Kawasaki-Motorcycle-Generator-Snowmobile/dp/B0049IFX56
It has just 1 wire, which wraps around the spark plug wire, and using induction, counts spark plug firing pulses.
I have used it a few times, just to check RPM at idle load and WOT, with stock prop and high thrust prop. I don't use it for hour meter. I'm not sure where one would put it for that purpose, what with rain and such.
That link got me thinking and off I went to Ebay.
This is the same thing I ordered. http://www.ebay.com/itm/28151837401...49&var=580545545975&ssPageName=STRK:MEBIDX:IT
I ordered 4. I'll be able to stuff them into the cowling so they are out of the way.
I didn't get the ones that do more than just hours as I am going to sell these motors at the end of the season and get new ones. The meters will go with the motors.
In the mean time I'm going to keep an eye out for a meter that does allot more. Things like Hours, RPM, Temp, etc. Maybe something I can plug an SD card ito so I can capture the data that way.
Any suggestions are welcome.
