Hello all. I have researched the archives and can't find the answer to this. I bought a 1974 Cat 27 which has been converted from an Atomic 4 with an outboard mount. I want to remove that mount and install a CMC PT-35 power tilt/trim unit. I ordered the tilt unit yesterday. I have never seen a Cat 27 that is properly set up for an outboard, so I have no idea where, or how large the cut the transom well. Also, it would be great to know chow they finished the edges of the cut at the factory. The only other option I can think of would be to install a Garelick Fixed Motor Bracket and install the CMC unit on that. I'm not sure that would hold the motor out far enough to actually tilt it all the way out of the water. Thanks,Tim
