- Oct 22, 2014
- 24,788
Randall,it takes no torque
What AG is saying - 5200 does not play well when it is under constant motion, as in the way the deck hardware is used. If you have a stanchion in a fixed position and no one is going to be grabbing it or pulling on it to get aboard then the adhesive and sealing properties of 5200 will not be challenged and will last a long time. When you have a stanchion used to pull crew aboard, or a winch that will be pulled (torqued) by sails and crew, then the movement will breakdown the adhesion of the 5200 and an opportunity for a leak is possible/probable. Butyl has a lot of stick even when pulled or torqued and is less prone to leaking in such situations. Additionally if you need to remove your winch at some future date, there is less chance you'll break the gelcoat or fiberglass under the winch with butyl than 5200.
