I launched Tally Ho yesterday morning….nice day on the south end of Lake Michigan….
I had installed a new Max Prop this spring, replacing my old 2-blade fixed prop. The new one is a 3-blade Max Prop Easy. I was really looking forward to the reverse thrust the prop is known for, and to get some extra speed while under sail.
I had talked to Fred at PYI several times as I was evaluating different props, and finally settled on the MaxProp because I wanted the ability to adjust the pitch.
I thought I had the prop set up correctly, but when I backed out of the slings yesterday, it sure didn’t seem like I had a lot of REV thrust. Then I took her for a little spin outside of the marina….engine at 3500 RPM’s and I was making around 3 knots
I reread the PYI manual, and had a bad feeling that the blades were not right….but I didn’t install them…the prop came assembled. But I DID mess around with the prop before installing it…so I must have done something to it.
I had some photos and a YouTube video so I sent those to Fred at PYI and he called me pretty quickly. He says it looks like the blades aren’t installed correctly…and he suggested pulling the boat, pulling the prop, and tearing it down and reassemble it correctly.
So, I have asked the marina if they can haul me out late tomorrow afternoon after their last launch, let me hang in the slings overnight during which time, I will pull the prop and re-assemble it, then put it back on and launch early on Thursday morning…bummer.
Fred and PYi have been very helpful and I am so looking forward to the new prop. The one thing I will say from my test t
drive yesterday was she runs really smooth. Even at 3500 rpm‘s, way less vibration than my old 2-blade prop.
While I was at the marina I installed a wifi surveillance camera that I bought for my house….you can connect to it where it is, as long as you have wifi there….
Every year when I launch Tally Ho, I get a lot of water in the bilge….I have no idea where it comes from….thruhulls are closed, no water around the various transducers…maybe rain water trapped in the pan…
So when I left yesterday, I set this camera down near the bilge, and I was able to monitor it for several hours. I could see the water rise to the line on the bilge pump, hear the pump kick on, see the water level drop and then slowly fill up again. But being able to see the pump do it’s thing made me feel better
The camera has infrared so even at night in the dark, I could see a black & white image of the bilge.
Today, after going to the marina and checking thing over, I used a shop vac and sucked the bilge dry….
and this afternoon ( photo was taken around 3:25 this afternoon)….bilge looks pretty dry
Now, to just get that prop thing figured out. Hopefully marina can pull me out tomorrow.
Cheers,
Greg
Cheers,
Greg
