My bad; you're absolutely right, Franklin!
A couple of days ago I was watching some other position data on the web that were much closer to the coast. In my mind I ended up associating that with Ken's voyage. However, just plotting his Dec 28 position data suggests he is still more than 1000 NM away and that he was much, much further away on Dec 20th. So the Humboldt (aka Peru) current has nothing to do with it (so I will remove my previous post to avoid confusion). Although my Google Earth program suggests that he covered 800+ NM in 8 days (i.e. between Dec. 20th and 28th), which is a bit more than Ross came up with. Even at 100 NM per day, however, he is still going a bit slower than one would expect.Right now the wind and seas in that area are pretty rough, according to the FNMOC South-America models. So, perhaps Ken has even been towing warps to slow the boat down a bit. The long-range forecast for the next 5-6 days has conditions moderating quite a bit, only to return to pretty rough conditions again by the middle of next week.With some luck, he might be able to worry about his telecom chores again in a few days.Flying Dutchman
