I wish him well too ...
I do, sincerely, wish him the very best of luck. I would never wish ill of another sailor.I also sincerely feel that he is not an experienced seaman. I think his choice of a 50,000 pound 44 foot boat is questionable. The poor light air performance should be no surprise. I cannot find much specific information about the Gulfstream 44. The 42 foot version is multi-chined, has a LWL of only 33.5 feet, and calls for 8,000 pounds of ballast. For reference 25% to 40% ballast displacement or "normal" figures. That puts the displacement at 32,000 to 20,000 pound or the Ballast/Displacement ratio under 20% ..? The working sail area on the 42 foot version is 810 sq. ft. with a light air rig of 1,337 sq. ft. Comparing to a Shannon 43 Ketch: The Shannon 43 displaces 29,000 pounds with 10,000 pounds of ballast for a 38% ballast/displacement ratio and about 1,000 sq. ft. of working sail area. The Shannon 43 is no hot rod. The Gulfstream 44 has pretty bad numbers for a pure sailboat. At 50,000 pounds it is either grossly overloaded or grossly overbuilt.His log mentions that he was not going to give up his hard earned miles south, so he was sailing toward a storm. "The sky in every direction was dark gray and black with heavy, thick cloud cover and you could feel everything around being sucked into its center. By first light I was reefed down to jib, staysail and triple-reefed mizzen. I was not about to give up an inch of the hard-won southing I had fought for over the past several days, so my course was east southeast toward the storm."The designer says that the bilge plates (that were cut off) are not needed if you don't mind giving up some of the boat's ability to sail to weather.I have to admit that I was wrong. This could be a first:"December 4 - South PacificAs reported in September's issue of Latitude 38, Southern California sailor Ken Barnes, 47, is currently attempting to become the first American singlehander to circumnavigate the globe nonstop, via the 'three capes', from the West Coast of North America.Sailing aboard Privateer, a Maurice Griffith-designed Gulfstream 44, this newcomer to the realm of bluewater sailing ..."His apparent lack of experience explains his choice of boat and his sailing tactics. "I was having a tough time making any southing due to direct headwinds and a loose headstay. . . One evening I'm sailing east southeast not making much southing, but a little, when I noticed the wind had shifted and I could pinch up a little. A few minutes later the same thing happened so I came up again. This went on until the lift was about 60 degrees. Boy, was I excited. I was finally headed only about 10 degrees off dead south and thinking I may nave finally hit the southeast trades, when suddenly I heard the off course alarm on the autopilot go off. It turned out that even though I was telling the autopilot to turn the boat and it was gallantly trying to, the boat would not respond because there was so much current that there was effectively no water passing over the rudder even though I was making 4 knots."Loose headstay? Did he leave without the rig being tuned or has something changed?"no water over the rudder ... I was making 4 knots ..."? Not possible. Unless he is using the GPS for speed instead of a knot meter. Are these the sort of errors that an experienced sailor makes?I wish him luck, indeed I do.
