? What does that mean?Do you want to STROBE the stars and sea surface?
No, an incomplete definition. Colregs considers the SOS lights a subcatagory of flashing light, and that is the only definition that matters in this context.verb [no object] 1 flash intermittently
It means that at night time and on angle the STROBE would signal the stars and the sea level.? What does that mean?
Websters:
1. strobescope.
Not to extend an argument here, but who said that hanging it would render it not level?It means that at night time and on angle the STROBE would signal the stars and the sea level.
Not very good if expecting the USCG to rescue you.
That is why it FLOATS or ≈ horizontal to Strobe SOS near you.
Waving by hand might help if a rescue was nearby.
I'll save you looking this up in ColReg's (Rule 1 - footnote 1): Submarines may display, as a distinctive means of identification, an intermittent flashing amber (yellow) beacon with a sequence of one flash per second for three (3) seconds followed by a three (3) second off-period. Other special rules made by the Secretary of the Navy with respect to additional station and signal lights are found in Part 706 of Title 32, Code of Federal Regulations (32 CFR 706)Was also under the impression that a strobe indicated a submarine traveling on the surface. I would not want to be a target for Putin unnecessarily.
Here is an answer...'though I'm not sure it's strong enough for OO-buck
Very good points. They are obviously designed to fit into your cupholders, since they don't hang straight. In that case you shouldn't even need to leave the cockpit to set it up! Remember to wear your shades though if you plan to be in the cockpit with it on. It's supposed to be pretty bright.Note that these flares transmit a horizontal beam of light, like and anchor light, and thus must be rigged dead level. The light hangs at about a 30 degree tilt with the supplied rigging. Also, bungees are all wrong, since it will snap back and forth if there is any sway. They also light for more than 8 hours; that's a long time to hand-hold! 5 minutes is a long tome to hold something steady overhead. I have not seen a single image on-line showing it rigged correctly.
All wrong. Only visible in two narrow sectors. Bad marketing materials. And there is nothing about this in the instructions.
The Orion version comes with a hanging bridle. You can rig a hanging bridle on C-1003 if you slide the float down to access two eyes. The C1002 has no means of rigging a bridle. Go figure.
Think about it. If some one handed this to you in an emergency you would ask two questions:
- How do I turn it on (they all have obvious switches or are twisted)?
- Where do I hang it? But they are not rigged for hanging
See post 15. Kinna obvious.Not to extend an argument here, but who said that hanging it would render it not level?
Oh yeah! With night-adapted vision, they are just plain painful! Which is a good thing, actually. But you do want to rig them above head level. (I tested them at night, taking pictures from a distance against background lights, to test conspicuousness.)Very good points. They are obviously designed to fit into your cupholders, since they don't hang straight. In that case you shouldn't even need to leave the cockpit to set it up! Remember to wear your shades though if you plan to be in the cockpit with it on. It's supposed to be pretty bright.
I love the flare gun-as-a-rotten-weapon videos!Here is an answer...
I was at home, 20 miles from the water.No. At least not near any coast guard covered area.
Only if you assume that goofy arrangement was what I was referring to. I was thinking that such a device should incorporate a means of hanging it. I'm going to be busy if I am in distress, I'm not going to be doing a Statue of Liberty impersonation in the cockpit.See post 15. Kinna obvious.
Video says it doesn’t replace flares…does that mean not CG approved?I went with the Ocean Signal EDF1 after nearly getting blinded by testing it at the boat show. It has a 7 year battery (you know you guys forget to replace the batteries right?). It will blind you and get you attention during the day as opposed to the one you guys are talking about.
