It appears that the sea cock for the engines raw water cooling is no longer closing completely and I'd like replace this ASAP. First of all the H34 is of the '86 vintage. While poking around, I noticed several folks seem to have the same valve. Secondly I have 2 questions...
1) I can't quite figure out the sea cocks model number or ID without removing it. Any help towards finding the correct seacocks would be appreciated.
2) I would like to replace ASAP this without having to haul the boat out... I just had it out a few months ago... I've read a few posts where someone had a diver cover the intake while making the change. Should the outside strainer be removed or is there some ingenious way of sealing the intake while the strainer is on.....
Thanks in advance!
Thanks in advance!
