Gunni, I don't know why you keep saying his boat is wrong. It works, without using adapters, and that's the safe way to go. I'm surprised no one suggested he check the panel AC breakers' size, the wire from there to SP inlet, and the rating of the two protective breakers, probably in the lazz. And I wouldn't say it is "unlikely" he has the service that he says he has. OEM or rewired, it is what his boat needs and has. I trust his cords are 30/10. You wouldn't put a 30-amp plug on a 50 cicuit or power cord, so might as well use 30/10 and either replace the male end with a 50 for the boat input, or buy a 30 to 50 pigtail. Perhaps the boat is 50-wired- including input- IN CASE he has 50 SP? You would not put a 30-to-50 adapter on the dock expecting to have 50 amps on the boat.
