Need or Want ?
Cherubini 37c HULL#37 Alameda
Is a windlass and a Rocna anchor a waste of money ? I don't anchor much. Or I should say didn't anchor much on Galveston bay when I was there. 12' of water and mud and really not to many desirable places to anchor but in SF bay Ive all ready seen some places I would be interested in overnighting at. I have a Fortess type anchor and 15' of chain which is about 70' too short for SF bay. Whats it like pulling up that much chain by hand ? I have a 32' boat and plan on doing quite a bit of coastal trips up and down California and Baja. What would be a good setup for me ? Ideas welcome.
544
Bristol 43.3 Perth Amboy
Two Issues here!
15 feet of chain is manageable with a bow roller, but how is your back? I have sailed my entire life until recently without a windlass. I have used electric windlasses in the caribbean on charter boats and like them. After 2 spine surgeries, my new to me boat has a windlass.
In terms of anchors, there is quite a bit written on this board about all the different anchors. That topic will usually bring out a lot of strong opinions! It is best to have an anchor larger than you need with more scope than recommended! In terms of type of anchor, look at the bottom conditions of where you will anchor and find anchors that excel in those conditions. Practical Sailor has done lots of testing.
Personally, I like to have different anchors on board, a Hi tensile Danforth, a CQR and a Bruce. My CQR is my working anchor.
May 5, 2006
1,140
Knutson K-35 Yawl Bellingham
I'd get a windlass. My Daughter and I dropped a 35 Lb CQR and 100' of 3/8" chain in what was supposed to be 60' of water for an excursion. It turned out to be 120' of water. Ya ever try to pull that much chain and the anchor when it's hanging straight down off the bow by hand? It wasn't fun at all.
Dave Groshong
SBO Staff
Staff member
Jan 25, 2007
1,867
Catalina 22 Seattle
I used to pull 80ft of 3/8 chain every time, then the rode, Charlie's right, not fun at all, but man was I in shape then!
zeehag
Mar 26, 2009
3,198
is why i use 5/16 on both my boats --is easier to muscle up than 3/8 and works just as well--i use 100 ft of it and on my ericson and for my formosa i have 300 ft on my main anchor-a cqr--with a windlass --and i have 100 ft for my danforth and my bruce is missing lol..needs to be replaced lol and its chain.....but i only use 5/16 chain..isnt gonna be as hard on the back and is easier to pull into the boat.......
Ross
Jun 15, 2004
14,693
Lacking a windlass but having a couple of two speed winches I spliced 30 feet of 3/8 line to a grab hook. With that I can winch my chain in from the deeps.
BobM
Jun 10, 2004
3,269
S2 9.2A Winthrop, MA
Ross, your idea is a good one. Now you just need one of those 28V 90 degree cordless drills with a head to fit the winch and bunch of batteries. You can power your anchor up and also use it to pull someone up the mast in a bosun's chair. They aren't cheap, but they are certainly cheaper than an electric windlass. The "official" version is $1000 (Winch Buddy)...but a 28V Milwaukee is $429 and the bit is about $40.
Ross
Jun 15, 2004
14,693
I would have to work harder and longer to get the money for the price of the motor and bit than I would to crank by hand.
Oct 12, 2009
63
beneteau 321 digby
less chain more rode
I have a 30 foot hunter and anchor regularly and I have a 35 lb danforth 12 feet of 3/8 chain and about 90 feet or rode.I dont need a winlass I would recommend you shorten up your chain and lighten your load and that will save your wallet as well as your back.
Bob S
Sep 27, 2007
1,815
Beneteau 393 New Bedford, MA
I have a 25# Mason Supreme with 60' 5/16 chain and 250' of nylon. I seldom anchor in more than 25' of water so pulling 25' of chain the 25# anchor hasn't been a problem. My problems have come when it's blowing 25-30kts with waves. It's a bear pulling the 10,000 lb boat over the anchor as I try directing the admiral in the right direction! It hasn't happen too often and we need more practice. Stu and Ross have suggested the chain hook to the winch trick. I rigged the chain hook to 30' of line. Now I need the snow to melt so I can get back to sailing and try it:dance:.
Eric M
Sep 30, 2008
159
Island Packet 35 Jacksonville
I have 250' of 5/16" chain and on my primary with a Rocna and I use the windlass 100% of the time to retrieve this. My secondary which I use 80% of the time I anchor is 15' of 5/16" chain connected to rode for the remainder. I have never used the windlass to retrieve the secondary, but in waters over 40' it is quite a chore. Both primary and secondary anchors are 35#.
Oct 25, 2005
735
Catalina 30 Banderas Bay, Mexico
Anything that is made easier get done more often. :)
In Mexico, you will be anchoring often. In some places the common practice is to anchor bow and stern.
Making what will be a daily chore while cruising into as little hassle as possible makes a windlass cost effective IMO.
What you have in SF bay and what you will see elsewhere down the coast are very different. Here in Mexico, Bruce types seem to be favoured as primary, Delta types second, and Fortress as lunch hooks/stern anchors. I don't see many CQR's. You will hear horror stories about any anchor you consider and passionate defense of every type by their owners. What works in sand might not work in loose mud or hard pack mud. Having more than one type of anchor is basic common sense. With a windlass, an anchor that lives on the roller while you are cruising can limit choices unless you are willing to change the setup to fit your anchor of choice.
If haven't read Latitude 38's First Timers Guide (link) you might enjoy it.
I lived in the SF Bay area for 25 years and anchored out maybe 5 times. Here in Mexico I anchor between 5 times a week and twice a day. Get the windlass.
Moody nailed it
If you're staying in the Bay, wander over and look at what I have on Aquavite. Rocna 10, 1/4 chain, 35 feet, no windlass. And we anchor out frequently (every other week sometimes). The 1/4 chain is easy to deal with, no back problems if you don't incorrectly retrieve the anchor (http://c34.org/bbs/index.php/topic,5064.0.html). This anchoring system was designed specifically for the Bay area, not for Mexico.
If you're really serious about going down the coast in the near future, set up for it now, or wait and pay twice.
A friend with a C34 has sailed down from Vancouver, BC, and reports here, reply #2: http://c34.org/bbs/index.php/topic,5270.0.html
Your Fortress would do OK in Clipper Cove and Horseshoe Cove and the Delta, but I wouldn't trust a fluke anchor in changing currents at China Camp or Paradise Cove.
Reply # 6 here discusses anchor system sizing: http://c34.org/bbs/index.php/topic,4990.0.html.
It's one of the two links in Reply #2 here: http://c34.org/bbs/index.php/topic,5307.0.html I recommend you read the other one, too, by Maine Sail, a great anchor selection discussion, also previously posted somewhere here and on hsi website, too.
Feb 6, 1998
11,772
Digby,
How do you get to a 7:1 scope, when necessary, with only 102 feet of rode.
With 3 feet of bow chock height and 11.5 feet of water depth you've maxed out you're rode for a 7:1 scope ratio in under 12 feet of water, and that would have to be at high tide if you sail in tidal waters?
Here in Maine we also have high tides, but not nearly as high as the Bay of Fundy. Figuring a 10 foot tide and 102 feet of rode to hit a 7:1 you'd need to anchor in 1.5 feet of water at LOW TIDE so you would not go over the 11.5 foot depth at high tide. In a Hunter 30 that is pretty tough.
To look at it another way if you anchored in 12 feet of water at low tide and then had a 10 foot tide added on to this. You would have a total depth to the bottom of; 3+22=25 feet. Scope is measured from bow chock to the ocean bottom. If you anchored in this 12 foot location at low tide, at high tide you would have a what could be a dangerously low scope of about 4:1 if any wind came up.
PK,
Fortress anchors don't require lots of chain and can still hold extremely well. Unfortunately the Fortress does not have the greatest track record for re-setting well on wind or tidal shifts, I know this first hand because I have one.
While you don't "need" a new anchor & rode it may be a good "want" to at least add another anchor to the arsenal. Basic rules of thumb are a minimum of 1 times boat length for chain, but from my experience, the majority of boats go with 1.5 times to 2 times boat length in chain..
What it all boils down to is what will allow YOU to sleep well at night. If 12 feet of chain and a Fortress will do that, then I would vote to keep your current set up and spend the boat bucks elsewhere...
Hey Stu, How's the leg ?
Ill be heading west on the 1st of Feb. I would value your opinion on getting a windlass setup for my boat. Perhaps we could get together when I'm in Alameda next month and talk about some options. I want to do it right the first time. PK
PK
Gettin' much better, just put the alternator back in Aquavite with my son's help on Sunday. For the first time since August I have a working boat that I cn actually use! How neat.
Sure, give me a heads up when you're coming, hi to Diane and your son.
COOL
Feb 16, 2009
118
Islander 30 mkII Downtown Long Beach
On that size boat, a windless is not a need to have,
It is just one more thing to break down and draw power(amps).
If you anchor infrequently, you can winch the anchor up
with one of the primaries, and not carry the weight penalty on the
bow when bashing to windward in large seas.
What does the size of the boat have to do with hauling all that ground tackle off the bottom with my back? A windlass isn't going to add enough weight (20 to 25 lbs.) to worry about. Ill leave a few gallons of water out of the v-birth tank. I have upgraded the electrical system and battery bank. It will handle what ever need I have for power. The reason I don't anchor much now is my bad back and the fact that I single hand alot. I'm no engineer so, the question is...... What would be the most efficient unit for the vessel. A 10,000 lb. boat and 120 lbs. of tackle. Ive decided, I want a windlass. I just don't know which one I need. A remote would come in handy too.
